Soil Moisture & Temperature Sensor
Rating:
60% of 100
Moisture and temperature of soil are two main concerns in agricultural area
$39.90
In stock
  • 10+: $35.91
  • 20+: $33.92
Moisture and temperature of soil are two main concerns in agricultural area. This sensor is prepared for applications that require precise monitoring over moisture and temperature conditions. The SHT-10 sensor inside brings satisfying high resolution. The typical temperature resolution is 0.4°C, while typical moisture resolution is 3%RH. With a copper sintered mesh over the sensor, you have no worry about its anticorrosion performance.
  • High resolution
  • Durable, stable and reliable
  • Industrial level gadget
  • Serial two-wire interface
  • Individually calibrated
Specifications
  • Temperature measuring range: -40 ~ +123.8°C
  • Moisture measuring range: 0 ~ 100% RH
  • Temperature accuracy: ±0.4°C
  • Moisture accuracy: ±3%RH
  • Cable in length: 1m
  • Wires: Red = VCC (3-5VDC), Black or Green = Ground, Yellow = Clock, Blue = Data.
Dimensions
Dimensions 80mm x120mm x15mm
Weight G.W 72.5g
Battery Exclude
ECCN ERA99
HSCODE 9025800000
USHSCODE 90230000
UPC 841454116240
Product Faqs
Sort by
