Water Flow Sensor YF-B7
It consists of a copper body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal.
$6.90
In stock
  • 2+: $6.56
  • 10+: $6.21
  • More
  • 50+: $5.87
  • Less
Water flow sensor consists of a copper body, a water rotor, and a hall-effect sensor. When water flows through the rotor, rotor rolls. Its speed changes with different rate of flow. The hall-effect sensor outputs the corresponding pulse signal. This one is suitable to detect flow in water dispenser or coffee machine.
Life is longer than plastic body.
• Compact, Easy to Install
• High Sealing Performance
• High Quality Hall Effect Sensor
• RoHS Compliant
Dimensions 0mm x0mm x0mm
Weight G.W 134g
Battery Exclude
Mini. Wokring Voltage DC 4.5V
Max. Working Current 15mA (DC 5V)
Working Voltage DC 5V~15V
Flow Rate Range 1~25L/min
Frequency F=11*Q(Q=L/MIN)
Load Capacity ≤10mA (DC 5V)
Operating Temperature ≤80℃
Liquid Temperature ≤120℃
Operating Humidity 35%~90%RH
Water Pressure ≤1.75MPa
Storage Temperature -25~+ 80℃
Storage Humidity 25%~95%RH
YF-B7 water flow sensor 1
ECCN ERA99
HSCODE 9026100000
USHSCODE 90261060
Product Faqs
Sort by
  • How many pulses per liter does the Water Flow Sensor YF-B7 output?
    Question by: Eduardo Vazquez on 2019-09-09 15:54:50
    Hi there~, If 1L water pass through, it will generate 11*60=660 pulses.  thanks.
    Answer by: admin on 2019-09-10 01:35:45
  • Refering again to YF-B4/7 what is the type of temp sensor and value of resistance vs temperature. From what i managed to find on internet it is 50kOhm at 25 degrees Celsius. I need 10kOhm at 25 deg Celsius. So again what is part no of original temp sensor?!
    Question by: Piotr Podkowa on 2019-07-17 09:27:12
  • Can you please upload any kind of datasheet for Water Flow Sensor YF-B7 and YF-B4 especially sizes of the thread...
    Question by: Piotr Podkowa on 2019-07-16 13:57:02
    Hi there~, They share the same spec and most of the parameters are the same. The only difference between YF-B7 and YF-B4 is the mechanical drawing. You can refer to mechanical drawing for the differences. Here is the link. thanks. https://github.com/SeeedDocument/Water-Flow-Sensor-datasheet
    Answer by: admin on 2019-07-17 10:01:16
  • What is the main difference between YF-B1 and this YF-B7? Does it support the same water pressure? How many pulses does this model produce per liter? Thanks
    Question by: Eduardo Vazquez on 2019-04-15 14:01:06
