DE-LIDAR TF02
This product is based upon TOF (Time of Flight), supplemented by particular optics, electricity, and design, so as to measure distance with stability, precision, high sensitivity, and high speed.
$99.00
Out of stock
Key Features
  • High sensitivity, and able to measure as far as 22 meters
  • High speed measurement with a maximum sampling frequency of 100Hz
  • Excellent anti-ambient light usability (operable under 100kLux ambient light
  • Protection grade: IP65
  • Anti-corrosive against pesticide
  • Small in size and light
Major Applications
  • Drone altitude holding and terrain following
  • Machine control and safe sensors
  • Range measuring instrument
Electrical Properties
Project
Symbol
Minimum Value
Typical Value
Maximum Value
Unit
Input Voltage
DC
4.5
5(≥1A)
6
V
Power
P
1
W
Peak CurrentIp
1
A
Serial Port TTL Electrical LevelLVTTL
0~3.3
V
Optical Properties
Project
Symbol
Condition or Description
Typical Value
Unit
Operating Range
L
Indoor
0.4 - 10 (Reflectivity 10%)
0.4 - 22
(Reflectivity 90%)
m
Outdoor illumination intensity of 100k Lux0.4 - 10 (reflectivity 30%)
Emission Semi-angle of Signal Light
α
Divergence angle of light spot
2
Degree
Signal Acceptance Semi-angle
β
Semi-angle of LiDAR’s effective detection
1.5
Degree
Range Resolution
Re
Sensitivity to range change
1
cm
Range Repeatability
σ
1σ standard deviation of indoor repetitive ranging
<1(within 10m) <2(10m-22m)
cm
Range Accuracy
Δ
Deviation between measuring range and actual distance
<6(within 5m)○2 <2%(5m-22m)
cm
Light Source
λ
Central wave length850
nm
Operating Temperature
T
10~60
︒ C
Protection GradeIP
IP65
Eye SafetySCompliance with EN62471NA
WeightWConnection line included52g
SizeLWHLength*Width*Height69*46*26mm
Dimensions 0mm x0mm x0mm
Weight G.W 164g
Battery Exclude
DE-LIDAR TF02 1
HSCODE 9031809090
USHSCODE 9015900190
Product Faqs
Sort by
