Loading...
Desoldering Wick
Desoldering wick for removing solder from printed circuit boards
$2.50
Out of stock
  • 10+: $2.25
  • 20+: $2.13
Desoldering wick for removing solder from printed circuit boards.
  • 1.5m length
  • 3.0mm width
How to use
  • Place the desoldering wick over the solder to be removed, then push the heated soldering iron tip onto the desoldering wick, the solder will be absorbed.
  • Remove the desoldering wick after the solder has been absorbed.
  • Cut off the used section of the wick using nippers.
  • Repeat above steps if the solder is not removed completely. Absorbability may differ depending on the type of solder. Sn63% and 60% (tin content) have good absorbability.
Dimensions 60mm x60mm x10mm
Weight G.W 12.5g
Battery Exclude
HSCODE 8007009000
UPC 841454114017
Documentations
Learn
