Mini Soldering Iron Deluxe Kit (US Standard)
Pocket size Programmable and open source Range from 100℃ to 400℃ Includes 2 types of iron tips
$99.00
In stock
  • 10+: $89.10
  • 20+: $84.15
Notice:
There might be abnormal noise when power connected due to Multi-slip cylindrical seat design.
Contact order@seeed.cc if you have any further need.
What is Mini Soldering Iron?
Mini Soldering Iron is a small, lightweight and rapid-heating (cold to 300℃ in 10 seconds) soldering iron with an OLED screen, which is perfect for kit building and other soldering applications.
This Mini Soldering Iron is programmable and the temperature can be controlled accurately from 100℃ to 400℃. Benefiting from the dual temperature and accelerator sensors, the soldering iron is equipped with the following two features to ensure users' safety: sleeping mode and over-heating notification.
The iron tip is replaceable and we include 2 types of iron tips in this package.
Mini Soldering Iron
Mini Soldering Iron
Mini Soldering Iron
Programmable system with free firmware upgrade, you could either program the temperate range or create your very own boot logo.
(adjust mode of gesture temperature will be coming soon)
Easy temperature control from 100℃ to 400℃.
Press Button A and B to heat up or cool the temperature down
We provide two types of iron tips “BC2” and “B2” to let you have more choices building your projects
Mini Soldering Iron
Mini Soldering Iron
Mini Soldering Iron
Dual temperature and accelerator sensors enable your to have a better safety and smart controlSmall and lightweight enough allows users to easily bring it with themOne package includes all the add-ons needed to use the Mini Soldering Iron for developing your projects
Specifications
ScreenOLED
USB PortMicro USB
Power PortDC5525
Operating Part DimensionsLength: 96mm, Diameter: 16.5mm
Heating Part DimensionsLength: 33mm, Diameter: 5.5mm
Weight33g (power adaptor not included)
Power65W
Adjustable Temperature Range100℃ - 400℃
Temperature Stability±2%
Voltage Input100V-240V
Part list
  • Mini Soldering Iron Operating Part x 1
  • PCB soldering kit
  • Soldering Iron Tip Type-BC2 x 1
  • Earth Clamps x 1
  • Soldering Tron Tip Type-B2 x 1
  • User Manual x1
  • Soldering Iron Stand x 1
  • Small Carrying Bag x1
  • DC5525 Power Adapter x 1
Documents
Dimensions 0mm x0mm x0mm
Weight G.W 487g
Battery Exclude
Mini Soldering Iron Deluxe Kit (US Standard) 1
ECCN ERA99
HSCODE 8515110000
USHSCODE 85151100
UPC 841454118435
Product Faqs
Sort by
