Loading...
Mecanum Wheel Kit (2 Left, 2 Right)
The Mecanum wheel is one design for a wheel which can move a vehicle in any direction
$99.00
Out of stock
The Mecanum wheel is one design for a wheel which can move a vehicle in any direction. It is a conventional wheel with a series of rollers attached to its circumference. These rollers each have an axis of rotation at 45° to the plane of the wheel and at 45° to a line through the center of the roller parallel to the axis of rotation of the wheel.
For more details about this kit, please refer to wiki
Features:
Omnidirectional transfer ability
Specification:
  • Diameter: 60mm
  • Width: 31mm
  • Number of Rollers: 8
  • Number of Plates:2
  • Body material: Aluminum alloy
  • Roller material: PP+PE
  • Spacer material: Nylon
  • Length of roller:30mm
  • Net weight:86g*4
  • Load capacity:10Kg
Part List:
  • 2×Left-handed Mecanum Wheel
  • 2×right-handed Mecanum Wheel
  • 4×Coupling for Lego Square shaft
  • 4×Coupling for Lego Cross shaft
  • 12×Hexagon Socket Head Cap Screw M3*40mm
Dimensions 0mm x0mm x0mm
Weight G.W 373g
Battery Exclude
HSCODE 9023009000
UPC 841454105954
Documentations
Documents
Learn
