USB controller for Nokia color LCD
THIS IS UNTESTED, NO LCD
THIS IS UNTESTED, NO LCD. SOLD 'AS-IS'.
Due to supply issues we can't source the LCD for this project. The USB backpack PCBs are sold 'as is' to keep them out of the landfill. You might be able to find a suitable LCD at SparkFun.
This is a simple USB controler for the inexpensive displays found in Nokia phones. Screen contrast and backlight brightness are adjustable from software. A small booster supplies 7volts for the backlight.
- Control inexpensive color LCDs over USB
- USB powered, boost converter supplies 7volts for the backlight
- Backlight is dimmable
- Minimum PCB size
- USB upgradable
- Open source (CC-BY-SA)
This open source hardware and software is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 10g |
HSCODE |
Show
per page
