the AI Hardware Partner
Toggle Nav
Loading...
7 Diagonal - 1280x800 IPS HDMI&VGA&NTSC&PAL Display
This is a pretty monitor for RPi, which has high performance and is convenient to use
$129.00
Out of stock
This is a pretty monitor for RPi, which has high performance and is convenient to use.
First of all, about its performance. The display part comes with a 7" TFT screen, which has a high resolution IPS with wide viewing angle.
HDMI/VGA/NTSC/PAL input sources are accepted.
How to use it? Just connect the included 9VDC adapter and video source, using buttons to adjust it to a comfortable setting. A basic stand is provided to fix it on the desk, or you can use the 4 'mounting thread' holes on the stand to attach the screen to other platforms. Also, there is a camera mount hole, which allows you to connect it to your camera to preview your pictures.
  • Power with 5-30VDC
  • Consumption: 6W
  • Input: VGA/HDMI/AV
  • Display ratio: 16:10
  • Visible area: 150mm x 95mm 16:10
  • Resolution: 1200 x 800, up to 1920*1080
Dimensions 0mm x0mm x0mm
Weight G.W 466g
Battery Exclude
HSCODE
