Loading...
7 Inch 1024x600 Capacitive Touch Screen DIY Kit
Rating:
100% of 100
Display, lcd, touchscreen, kit, raspberry pi kit, diy kit, education
$59.95
Out of stock
  • 10+: $56.95
  • 20+: $53.96
  • More
  • 50+: $50.96
  • Less
This is a new DIY kit for all makers; it is a fantastic HDMI monitor with capacitive touch screen and driver free. We added a CTP driver board and provided a capacitive touch screen to make it a whole new suite. After that, you don't need to calibrate your touch screen, and make your 7 inch display a touch screen. It's been tested on Raspberry Pi, beagle bone black, PC and Mac book. And it works well on those platforms and it is really plug and play.
  • It supports 1024x600 resolution and supports approximate 30fps, maximum 60fps
  • The capacitive touch function give the user full control over any device.
  • It's driver free for your device due to built-in EDID device information.
  • It is very easy to let the equipment correctly identified the touch screen.
  • The Capacitive USB touch screen can support functions of the right mouse button and drag and drop.
  • It can support multipoint touch, maximum 10 points. (Only test in windows 10)
Connection Details
The CTP driver board has two USB port type, one of them is a MicroUSB cable on the right side.
(Both of them are available for your touch screen, one of them should be connected to the output device.)
Work with Raspberry Pi
If you are using Raspberry Pi, you can change resolution by these steps:
Login to your Raspberry Pi and edit /boot/config.txt file, make sure it has following parameter:
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1024 600 60 3 0 0 0
Save it and reboot your system.
If touch screen is out of work please make sure you connect the Display’s MicroUSB Port to your device (PC, Raspberry Pi, Beagle bone black etc.)
Note:
We are not sure it can work at android system due to it dose not test in android OS yet.
If you find that the screen is blur when you connect it to your device, please check the FPC cable on the back of driver board, it may loose when it was shipping to you. Just pull out the block of the FPC cable and put the FPC wires into it and make sure it fasten tightly and retry it again. Please take care of this cabin cable; it’s connected to the board and sends the touch screen data to the chip on the board.
If you are willing to know more information about Raspberry Pi display, please view the table as follow.
Product nameResolutionPower supplyDisplay interfaceFor use withDimension(mm)Touch panel typeDisplay tec.
5 inch 720x1280 HDMI IPS LCD Display 720x1280 5V HDMI2.0 Raspberry Pi3, Windows, etc. 134x84 None IPS
5 inch 800x480 Capacitive TouchScreen 800x480 5V HDMI & USB 2.0 Raspberry Pi3, Windows, etc. 184x106x45 Capacitive TFT
5 Inch HDMI Display with USB TouchScreen 800x480 5V HDMI & USB 2.0 Raspberry Pi3, Pi4, Windows, etc. 170x90x40 Resistive TFT
5 inch Capacitive touch screen & Acrylic Case Kit 800x480 5V HDMI & USB 2.0 Raspberry Pi3, Windows, etc. 210x150x50 Capacitive TFT
7 inch 720x1280 HDMI IPS LCD Display 720x1280 5V HDMI2.0 Raspberry Pi3, Pi4, Windows, etc. 192x118 None IPS
Raspberry Pi 7 inch Touchscreen Display 800x480 5V Display ribbon cable Raspberry Pi3, Pi2, Pi 194x110x20 Capacitive TFT
7 Inch 1024x600 Capacitive Touch Screen With Camera Kit 1024x600 5V HDMI & USB 2.0 Raspberry Pi3, Windows, etc. 177x113x15 Capacitive TFT
10.1 inch 1200x1920 HDMI IPS LCD Display 1200x1920 5V HDMI2.0 Raspberry Pi3, Pi4,Windows,etc. 255x165 None IPS
15.6 Inch 1920*1080 Full HD IPS Touch Screen Portable Monitor 1920x1080 5V Mini DP/ Mini HDMI / Type C Raspberry Pi3,Pi4,Windows,etc. 375x230x12 Capacitive IPS
7 Inch HDMI 1280x800 IPS Display 1280x800 7.5V~12V AV + VGA + HDMI (HDMI 1.2) Raspberry Pi3, Windows, etc. 162x106x5 None IPS
7 Inch 1024x600 Capacitive Touch Screen DIY Kit 1024x600 5V AV + VGA + HDMI (HDMI 1.2) Raspberry Pi3, Windows, etc. 265x165x50 Capacitive TFT
10.1 Inch LCD Display - 1366x768 HDMI&VGA&NTSC&PAL 1366x768 5V~24V AV + VGA + HDMI (HDMI 1.2) Raspberry Pi3,Pi4,Windows,etc. 230x150x5 None TFT
Raspberry Pi HDMI LCD (10.1 inch) 1280x800 5V HDMI & USB 2.0 Raspberry Pi3,Pi4,Windows,etc. 290x200x35 Capacitive IPS
Dimensions 265mm x165mm x50mm
Weight G.W 410g
Battery Exclude
Operating voltage 5V (current requirement 2A), 9V@1.5A(Recommended), 12V@1A
Rated power 6-7W
Signal input AV + VGA + HDMI (HDMI 1.2)
Resolution 1024 * 600
Plug and Play free driver
OSD language Simplified Chinese, Traditional Chinese, English, Japanese, Korean, Spanish, French, German, Italian, Portuguese
Control Multi-function OSD operation or potentiometer adjust the brightness and color
Using mature program clear display
Multipoint touch, maximum 10 points (Only test in windows 10)
Support image flip up and down the image can conversion 4: 3 / 16: 9 display format
Support 30fps maximum 60fps
7 inch 1024x600 High Resolution Screen 1
7 inch Capacitive Touch Panel 1
HDMI/VGA/S-Video Video driver board 1
CTP driver board (Capacitive Touch Panel Driver board) 1
Key board 1
Key board cable wire 1
Driver board Power supply cable wire 1
USB touch screen cable wire 1
HSCODE 8528521200
Documentations
Learn
  1. Rating
    100%
    Great quality screen, very clear. Touch screen needs some getting used to, big fingers sometimes touch wrong items.
    By
1 Item
Show per page
