Ethernet Shield
  • Ethernet Shield
  • Ethernet Shield
  • Ethernet Shield
Ethernet Shield
SKU 113030012
This product was replaced by a updated version W5200 Ethernet Shield (SLD91000P)
$19.90
DISCONTINUED
This product was replaced by a updated version W5200 Ethernet Shield (SLD91000P).
Ethernet Shield instantly enables internet connectivity for Arduino projects. An on-board Wiz5100 ethernet controller handles up to four TCP and UDP connections, just stack it onto an Arduino to create your own networked devices. Easily check connection status with on board indicator lights. Extend your design further with two extra rows of pin header that connect to shields and prototyping boards.
  • Standard Arduino and Arduino Mega compatible
  • Arduino Ethernet Library compatible
  • Standard RJ45 ethernet Jack
  • 16K byte internal buffer
  • Indicator LEDs for all functions
  • Easy to access reset button
  • Standard pin headers for 0.1"grid prototyping boards
  • Up to 4 TCP/UDP network connections
Specifications
Item
 Min
 Typical
 Max
 Unit
Voltage
3.5
5
5.5
V
Current
120
210
350
mA
Dimension
72.6 x 58.4 x 23.2
mm
Supported Connection
TCP/UDP
Net Weight
24.2
g
Documents
Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
i just got this shield and when i opened the webclient example it wants me to enter the mac address of the shield it sides that Newer Ethernet shields have a MAC address printed on a sticker on the shield but this one dosent have it plz help
on Oct 19,2016
Replyupvote ()
Hi.You can scan all MAC of devices which connected to your PC via router.And you can use the default MAC which our demo has used instead of your ethernet's MAC.
on Oct 20,2016 10:45 AM
Replyupvote ()
Reply
0
I have a problem when I am working with ethernet shield v 1.1 and SD card Shield v 4.1 to same time I cannot to access to SD card to read or write but when a remove the ethernet shield works good I used the liberty ethernet and SD , I put the pin 10
on Oct 19,2016
Replyupvote ()
Hello Cesar,I
I am having the same problem. Did you get this resolved? If so, how?
Thank You.
on Oct 20,2016 10:49 AM
Replyupvote ()
Same problem. Need Help
Replyupvote ()
Reply
0
Hi,
I like build a FTP Server,
then I can access to SD files remotly from PC.
Then how to build a FTP Server?
on Oct 19,2016
Replyupvote ()
Hi,Here is a link,(http://forum.arduino.cc/index.... you can refer it and try it to build FTP server~~enjoy it.
on Oct 20,2016 10:46 AM
Replyupvote ()
Reply
0
Hi I purchased this board a few weeks ago and have been having trouble getting to the interface page once it has been flashed . I am following the instructions set forth on the wiki page , but still no luck I a able to ping the device on the 192.168.1.
on Oct 19,2016
Replyupvote ()
Hi,Ledger.If you can compile without errors,but still not connect to the web site,may it's a problem of your libraries.I have dropped a line to you with a new libraries therein,you can have a try.
on Oct 20,2016 10:43 AM
Replyupvote ()
hello,Sorry,isn't included the Cable.and you can get by other ways
Replyupvote ()
Reply
See More
View History
Documents
Recommendations
SUBMIT
Invalid email address.
