the AI Hardware Partner
Toggle Nav
Loading...
Xadow - GPS
Xadow GPS is an OEM GNSS receiver module, including the Fastrax IT530M and a tiny 12mm squared ceramic patch antenna
$24.90
Out of stock
Xadow GPS is an OEM GNSS receiver module, including the Fastrax IT530M and a tiny 12mm squared ceramic patch antenna. The low power module outputs a series of standard NMEA format data which provides position, satellite information and time, etc. This module can be easily connected directly to Xadow Main board to display and record the above-mentioned information. It features acquisition and tracking capability of weak signals, making it a great choice for navigation projects.
FEATURES
  • Low power
  • Extremely fast TTFF (Time To First Fix)
  • Supports NMEA data protocol
  • Very High Sensitivity (Tracking Sensitivity: -165dBm)
  • Compatible with Xadow Modules
Xadow is a though small but perfectly formed Arduino(TM) compatible board series containing several modules. It's a kit extremely suitable for space-sensitive projects such as wearable devices & arts designs, which have higher request on size, weight and flexible cascade connection. You can find more modules here.
DOCUMENTS
NOTE
This module is not compatible with any other Xadow version 2 or RePhone modules.
Dimensions 0mm x0mm x0mm
Weight G.W 15g
Battery Exclude
Xadow - GPS 1
GPS Antenna 1
HSCODE 8529905000
USHSCODE 8526910020
UPC 841454101376
COO CHINA
