101020056 | Grove - Gas Sensor(MQ5) | Analog | 5V | | | | | | |
101020044 | Grove - Alcohol Sensor | Analog | 5V | | | | | | |
101020010 | Grove - Ultrasonic Ranger | Digital | 3.3V/5V | | | | | | |
101020057 | Grove - Fingerprint Sensor | UART | 5V | | | | | | |
101020172 | Grove - Line Finder v1.1 | Digital | 3.3V/5V | | | | | | |
101020012 | Grove - Dust Sensor | Digital | 5V | | | | | | |
101020083 | Grove - Gesture | I2C | 3.3V/5V | | | | | | |
101020018 | Grove - Water Sensor | Digital | 3.3V/5V | | | | | | |
101020001 | Grove - HCHO Sensor | Analog | 5V | | | | | | |
101020019 | Grove - Temperature&Humidity Sensor Pro | Digital | 3.3V/5V | | | | | | |
101020020 | Grove - PIR Motion Sensor | Digital | 3.3V/5V | | | | | | |
111020002 | Grove - High Temperature Sensor | Analog | 3.3V/5V | | | | | | |
101020023 | Grove - Sound Sensor | Analog | 3.3V/5V | | | | | | |
101020074 | Grove - Temperature&Humidity Sensor (High-Accuracy & Mini) | I2C | 3.3V/5V | | | | | | |
101020046 | Grove - Hall Sensor | Digital | 5V | | | | | | |
101020042 | Grove - 80cm Infrared Proximity Sensor | Analog | 3.3V/5V | | | | | | |
101020026 | Grove - Infrared Emitter | Digital | 3.3V/5V | | | | | | |
101020052 | Grove - GSR sensor | Digital | 3.3V/5V | | | | | | |
101020212 | Grove - Temp&Humi Sensor(SHT31) | I2C | 3.3V/5V | | | | | | |
101020011 | Grove - Temp&Humi Sensor | Digital | 3.3V/5V | | | | | | |
101020051 | Grove - 3-Axis Analog Accelerometer | I2C | 3.3V/5V | | | | | | |
101020192 | Grove - Barometer Sensor (BMP280) | I2C | 3.3V/5V | | | | | | |
101020341 | Grove - I2C Color Sensor v2.0 | I2C | 3.3V/5V | | | | | | |
101020080 | Grove - IMU 9DOF v2.0 | I2C | 3.3V/5V | | | | | | |
101020175 | Grove - IR Distance Interrupter v1.2 | Digital | 3.3V/5V | | | | | | |
101020033 | Grove - Ear-clip Heart Rate Sensor | Digital | 3.3V/5V | | | | | | |
101020174 | Grove - Infrared Reflective Sensor v1.2 | Digital | 3.3V/5V | | | | | | |
101020132 | Grove - Light Sensor v1.2 | Analog | 3.3V/5V | | | | | | |
101020008 | Grove - Moisture Sensor | Analog | 3.3V/5V | | | | | | |
101020015 | Grove - Temperature Sensor | Analog | 3.3V/5V | | | | | | |
101020063 | Grove - Loudness Sensor | Analog | 3.3V/5V | | | | | | |
101020016 | Grove - Infrared Receiver | Digital | 3.3V/5V | | | | | | |
101020031 | Grove - Piezo Vibration Sensor | Analog | 3.3V/5V | | | | | | |
101020078 | Grove - Air quality sensor v1.3 | Analog | 3.3V/5V | | | | | | |
101020037 | Grove - Touch Sensor | Digital | 3.3V/5V | | | | | | |
101020030 | Grove - Digital Light Sensor | Digital | 3.3V/5V | | | | | | |
101020013 | Grove - RTC | I2C | 3.3V/5V | | | | | | |
101020054 | Grove - 3-Axis Digital Accelerometer(±16g) | I2C | 3.3V/5V | | | | | | |
101020173 | Grove - Light Sensor(P) v1.1 | Analog | 3.3V/5V | | | | | | |
101020000 | Grove - Serial Camera Kit | UART | 5V | | | | | | |
101020089 | Grove - Sunlight Sensor | I2C | 3.3V/5V | | | | | | |
101020088 | Grove - Multichannel Gas Sensor | I2C | 3.3V/5V | | | | | | |
101020252 | Grove - IMU 10DOF v2.0 | I2C | 3.3V/5V | | | | | | |
101020076 | Grove - Luminance Sensor | Analog | 3.3V/5V | | | | | | |
101020055 | Grove - Gas Sensor(MQ2) | Analog | 5V | | | | | | |
101020027 | Grove - Electricity Sensor | Analog | 3.3V/5V | | | | | | |
101020068 | Grove - Barometer (High-Accuracy) | I2C | 3.3V/5V | | | | | | |
105020012 | Grove - 6-Axis Accelerometer&Gyroscope | I2C | 3.3V/5V | | | | | | |
101020039 | Grove - 3-Axis Digital Accelerometer(±1.5g) | I2C | 3.3V/5V | | | | | | |
101020002 | Grove - Gas Sensor(O2) | Analog | 5V | | | | | | |
101020062 | Grove - Infrared Temperature Sensor | Analog | 3.3V/5V | | | | | | |
101020232 | Grove - Speech Recognizer v1.0 | Digital | 3.3V/5V | | | | | | |
101020193 | Grove - Barometer Sensor(BME280) | I2C | 3.3V/5V | | | | | | |
101020067 | Grove - CO2 Sensor | UART | 5V | | | | | | |
101020045 | Grove - Gas Sensor(MQ9) | Analog | 5V | | | | | | |
101020043 | Grove - UV Sensor | Analog | 3.3V/5V | | | | | | |
101020058 | Grove - EMG Detector | Analog | 3.3V/5V | | | | | | |
101020049 | Grove - Flame Sensor | Digital | 5V | | | | | | |
101020077 | Grove - Digital Infrared Temperature Sensor | I2C | 3.3V/5V | | | | | | |
101020082 | Grove - Finger-clip Heart Rate Sensor with shell | I2C | 3.3V/5V | | | | | | |
101020006 | Grove - Gas Sensor(MQ3) | Analog | 5V | | | | | | |
101020050 | Grove - 3-Axis Digital Gyro | I2C | 3.3V/5V | | | | | | |
102020083 | Grove - High Precision RTC | I2C | 3.3V/5V | | | | | | |
101020005 | Grove - Collision Sensor | Digital | 3.3V/5V | | | | | | |
101020047 | Grove - I2C Touch Sensor | I2C | 3.3V/5V | | | | | | |
103020024 | Grove - Finger-clip Heart Rate Sensor | I2C | 3.3V/5V | | | | | | |
103020030 | Grove – Mouse Encoder | Digital | 3.3V/5V | | | | | | |
101020081 | Grove - 6-Axis Accelerometer&Compass v2.0 | I2C | 3.3V/5V | | | | | | |
101020312 | Grove - Heelight Sensor | Digital | 3.3V/5V | | | | | | |
101020071 | Grove - 3-Axis Digital Accelerometer(±400g) | I2C | 3.3V/5V | | | | | | |
101020069 | Grove - Q Touch Sensor | I2C | 3.3V/5V | | | | | | |
101020353 | Grove - Mini PIR Motion Sensor | Digital | 3.3V | | | | | | |
101020009 | Grove - Line Finder | Digital | 3.3V/5V | | | | | | |
105020005 | Grove - EL Driver | Digital | 3.3V/5V | | | | | | |
104030009 | Grove - White LED | Digital | 3.3V/5V | | | | | | |
104030010 | Grove - Blue LED | Digital | 3.3V/5V | | | | | | |
104030005 | Grove - Red LED | Digital | 3.3V/5V | | | | | | |
104030007 | Grove - Green LED | Digital | 3.3V/5V | | | | | | |
104030014 | Grove - Multi Color Flash LED (5mm) | Digital | 3.3V/5V | | | | | | |
104020001 | Grove - Variable Color LED | Digital | 3.3V/5V | | | | | | |
105020002 | Grove - LED Strip Driver | Digital | 3.3V/5V | | | | | | |
104030013 | Grove - Circular LED | Digital | 5V | | | | | | |
104020005 | Grove - LED String Light | Digital | 3.3V/5V | | | | | | |
104020048 | Grove - Chainable RGB LED v2.0 | Digital | 3.3V/5V | | | | | | |
101020091 | Grove - Mini Track ball | I2C | 3.3V/5V | | | | | | |
101020048 | Grove - Rotary Angle Sensor(P) | Analog | 3.3V/5V | | | | | | |
101020004 | Grove - Switch(P) | Digital | 3.3V/5V | | | | | | |
111020000 | Grove - Button(P) | Digital | 3.3V/5V | | | | | | |
101020036 | Grove - Slide Potentiometer | Analog | 3.3V/5V | | | | | | |
101020003 | Grove - Button | Digital | 3.3V/5V | | | | | | |
101020028 | Grove - Thumb Joystick | Analog | 3.3V/5V | | | | | | |
101020038 | Grove - Magnetic Switch | Digital | 3.3V/5V | | | | | | |
101020017 | Grove - Rotary Angle Sensor | Analog | 3.3V/5V | | | | | | |
101020025 | Grove - Tilt Switch | Digital | 3.3V/5V | | | | | | |
111020001 | Grove - Encoder | Digital | 3.3V/5V | | | | | | |
104030001 | Grove - LCD RGB Backlight | I2C | 3.3V/5V | | | | | | |
104030008 | Grove - OLED Display 0.96'' | I2C | 3.3V/5V | | | | | | |
104030003 | Grove - 4-Digit Display | Digital | 3.3V/5V | | | | | | |
104020006 | Grove LED Bar v2.0 | Digital | 3.3V/5V | | | | | | |
104030011 | Grove - OLED Display 1.12'' | I2C | 3.3V/5V | | | | | | |
113020008 | Grove - Serial Bluetooth v3.0 | UART | 5V | | | | | | |
113020003 | Grove - GPS | UART | 3.3V/5V | | | | | | |
113020002 | Grove - 125KHz RFID Reader | UART | 5V | | | | | | |
113020001 | Grove - 315MHz Simple RF Link Kit | UART | 5V | | | | | | |
107020006 | Grove - I2C FM Receiver | I2C | 3.3V/5V | | | | | | |
113020010 | Grove - Uart Wifi | UART | 3.3V/5V | | | | | | |
113020006 | Grove - NFC | I2C | 3.3V/5V | | | | | | |
113060000 | Grove - 433MHz Simple RF link kit | Digital | 3.3V/5V | | | | | | |
113060006 | Grove - LoRa Radio 868MHz | UART | 3.3V/5V | | | | | | |
113020007 | Grove - BLE | UART | 3.3V/5V | | | | | | |
113060007 | Grove - LoRa Radio 433MHz | UART | 3.3V/5V | | | | | | |
113020009 | Grove - BLE (dual model) | UART | 3.3V/5V | | | | | | |
113020000 | Grove - Serial RF Pro | UART | 5V | | | | | | |
101020070 | Grove - NFC Tag | I2C | 3.3V/5V | | | | | | |
103020005 | Grove - Relay | Digital | 3.3V/5V | | | | | | |
107020000 | Grove - Buzzer | Digital | 3.3V/5V | | | | | | |
107020001 | Grove - Speaker | Digital | 5V | | | | | | |
101020073 | Grove - Electromagnet | Digital | 5V | | | | | | |
316010005 | Grove - Servo | Digital | 5V | | | | | | |
107020029 | Grove - Recorder v3.0 | Digital | 3.3V/5V | | | | | | |
103020014 | Grove - Dry-Reed Relay | Digital | 3.3V/5V | | | | | | |
105020001 | Grove - I2C Motor Driver | I2C | 3.3V/5V | | | | | | |
107020008 | Grove - MP3 v2.0 | Digital | 5V | | | | | | |
105020003 | Grove - Vibration Motor | Digital | 3.3V/5V | | | | | | |
108020021 | Grove - Mini Fan v1.1 | Digital | 3.3V/5V | | | | | | |
105020010 | Grove - I2C Mini Motor Driver | I2C | 3.3V/5V | | | | | | |
103020012 | Grove - SPDT Relay(30A) | Digital | 5V | | | | | | |
101020090 | Grove - Water Atomization v1.0 | Digital | 5V | | | | | | |
103020010 | Grove - 2-Coil Latching Relay | Digital | 5V | | | | | | |
105020011 | Grove - Haptic Motor | I2C | 3.3V/5V | | | | | | |
103020004 | Grove - Solid State Relay | Digital | 3.3V/5V | | | | | | |
103020007 | Grove - Screw Terminal | Digital | 3.3V/5V | | | | | | |
103020008 | Grove - MOSFET | Digital | 3.3V/5V | | | | | | |
103020006 | Grove - I2C Hub | I2C | 3.3V/5V | | | | | | |
101020035 | Grove - Protoshield | Others | 3.3V/5V | | | | | | |
104020000 | Grove - Voltage Divider | Analog | 3.3V/5V | | | | | | |
103020011 | Grove - RJ45 Adapter | Others | 3.3V/5V | | | | | | |
103020013 | Grove - I2C ADC | I2C | 3.3V/5V | | | | | | |
103020000 | Grove - DMX512 | Digital | 3.3V/5V | | | | | | |
103020016 | Grove - Differential Amplifier | Others | 3.3V/5V | | | | | | |
103020002 | Grove - Bee Socket | UART | 3.3V/5V | | | | | | |
103020009 | Grove - Nunchuck | I2C | 5V | | | | | | |
101020034 | [EOL]-Grove - 3-Axis Digital Compass | I2C | 3.3V/5V | | | | | | |
101020040 | [EOL]-Grove - IR Distance Interrupter | Digital | 3.3V/5V | | | | | | |
101020014 | [EOL]-Grove - Light Sensor | Analog | 3.3V/5V | | | | | | |
101020029 | [EOL]-Grove - Infrared Reflective Sensor | Digital | 3.3V/5V | | | | | | |
101020072 | [EOL]-Grove - Barometer Sensor (BMP180) | I2C | 3.3V/5V | | | | | | |
101020087 | [EOL]-Grove - Temperature&Humidity Sensor(HDC1000) | I2C | 3.3V/5V | | | | | | |
101020022 | [EOL]-Grove - Light Sensor(P) | Analog | 3.3V/5V | | | | | | |
101020032 | [EOL]-Grove - Barometer Sensor | I2C | 3.3V/5V | | | | | | |
101020053 | [EOL]-Grove - Single Axis Analog Gyro | Analog | 3.3V/5V | | | | | | |
104030006 | [EOL]-Grove - Chainable RGB LED | Digital | 3.3V/5V | | | | | | |
104020002 | [EOL]-Grove - Purple LED (3mm) | Digital | 3.3V/5V | | | | | | |
105020013 | [EOL]-Grove - LED Matrix Driver v1.0 | UART | 3.3V/5V | | | | | | |
107020005 | [EOL]-Grove - FM Receiver | Digital | 3.3V/5V | | | | | | |
103020018 | [EOL]-Grove - Recorder | Digital | 3.3V/5V | | | | | | |
105020004 | [EOL]-Grove - Mini Fan | Digital | 3.3V/5V | | | | | | |
101020079 | [EOL]-Grove - IMU 10DOF | I2C | 3.3V/5V | | | | | | |
101020041 | [EOL]-Grove - I2C Color Sensor | I2C | 3.3V/5V | | | | | | |
