Customize Your XIAO for Production: Firmware, Headers, Assembly & More
Seeed Fusion: From XIAO Prototype to Production-Ready Solution
XIAO has helped thousands of developers quickly build compact IoT, wearable, robotics, and embedded projects. However, when moving from a prototype to a small production batch, developers often encounter practical challenges:
  • Hundreds of boards need the same firmware
  • Manual soldering becomes inefficient
  • Different applications require different XIAO configurations
  • Existing designs need a simple hardware adjustment
Instead of redesigning your entire solution, Seeed Fusion provides lightweight XIAO customization services to help developers efficiently prepare their projects for production—without manually programming and assembling every unit.
🔍From firmware programming and header soldering to board assembly and model migration, these services can be tailored to your specific production requirements.
1️⃣ Firmware Pre-Programming: Ready-to-Use XIAO Devices
One of the most common XIAO customization requirements is firmware flashing.
For small-batch production, manually programming every XIAO board can be time-consuming and error-prone.
What You ProvideWhat Seeed Fusion Supports
Firmware binary file (.bin)✅Batch firmware flashing
Programming instructions✅Firmware verification
Test requirements (if applicable)✅Basic testing and production preparation
Typical Applications: IoT sensors · BLE devices · LoRa nodes · Smart hardware products
2️⃣ Header Soldering: Make XIAO Ready for Integration
Although XIAO’s compact design makes it powerful, different applications require different connection methods.
Some customers need:
  • Male headers
  • Female headers
  • Specific pin configurations
Instead of manually soldering hundreds of boards, Seeed Fusion can make XIAO boards that are ready for integration. ✅This helps save assembly time, improve consistency, and reduce manual labor.
3️⃣ XIAO Assembly: Combining Multiple Boards for Specific Applications
Application Example: Dual XIAO Assembly
Some XIAO-based applications require two boards to be combined into one compact module for custom development platforms, specialized communication devices, or other integrated products.
Seeed Fusion handles mechanical alignment, soldering, and batch assembly to ensure stable connections and consistent quality across every unit, which allows developers to focus on product development instead of manual assembly.
Turn separate XIAO boards into a compact, consistently assembled module ready for product integration.
4️⃣ XIAO Replacement: Upgrade Your Existing Design
During product development, customers may find that a different XIAO model better matches their requirements.
For example:
  • Replace XIAO ESP32-C6 with XIAO ESP32-S3
  • Replace one wireless module with another
  • Upgrade computing capability or memory
Seeed Fusion can support XIAO model replacement based on:
  • Application requirements
  • Firmware compatibility
  • Hardware integration needs
Ready to Customize Your XIAO Project?
Share your XIAO model, estimated quantity, required modifications, and firmware needs with us. Our team will evaluate your requirements and recommend the most suitable customization and production approach—from prototyping to volume production.
❓If you have any other questions, feel free to contact us at [email protected]
August 2026
3456789
10111213141516
17181920212223
24252627282930
31
