Navigating New Customs Regulations: Important Update for US Orders from Our China Warehouse
To ensure the smoothest possible experience for our valued customers, we are providing an important update regarding recent changes to export procedures that may affect shipments from our China warehouse to the United States.
What’s Changed?
Chinese customs authorities have implemented updated declaration and inspection procedures, as outlined in the Regulations on the Administration of Declaration for Import and Export Goods (Decree No. 277). A key focus of this enhanced oversight is on goods listed under the official Catalogue of Import and Export Control of Dual-Use Items and Technologies.
“Dual-use items” typically include electronics, components, equipment, or software that have both commercial and potential military applications. Many common products in the maker, IoT, and advanced technology sectors may fall under this broad category.
Potential Impact on Your Order
As a result of this increased scrutiny, orders containing applicable items are experiencing a higher rate of documentary checks and physical inspections at the port of export.
Based on recent data, we estimate that 10-20% of such US-bound shipments may face a customs processing delay of approximately 7 to 15 business days. This is outside of our control and in addition to standard shipping times.
For time-sensitive orders: Please contact us before or immediately after placing your order if delivery timing is a strict priority. By reaching out early, our logistics team can review your order contents, provide a current risk assessment, and discuss potential solutions or alternatives with you.
Contact Point for Urgent Inquiries:
Email: [email protected]
Please include your order number (if available) or a list of intended products in your message.
We sincerely appreciate your understanding and patience. Thank you for your continued trust in us.
| SKU | Product Name |
| 113990051 | NFC Antenna |
| 318020068 | RF Explorer Cloverleaf dual band 2.4&5.8Ghz omnidirectional SMA |
| 318020070 | Directional Patch 2.4Ghz SMA Articulated Antenna |
| 320160012 | SMA M&M 6GHz Semi-Flexible cable RG402 – 10cm |
| 320160013 | SMA M&F 6GHz Semi-Flexible cable RG402 – 10cm |
| 114990811 | RF Explorer Near Field Antenna Kit |
| 109990205 | Rubber Duck UHF 400-900MHz SMA Articulated Antenna |
| 318020069 | Directional Patch 5.8Ghz SMA Articulated Antenna |
| 318020009 | Nagoya NA-773 antenna |
| 113990495 | LTE-M Antenna for Pycom |
| 318020023 | Omnidirectional 4G/LTE SMA Antenna |
| 318020010 | 2.4GHz Whip Rubber Antenna |
| 318020021 | Rubber Duck 5.8Ghz SMA Articulated Antenna |
| 114990711 | RF Explorer H-Loop Near Field Antenna (RFEAN25) |
| 113990374 | SARK-110-ULM Antenna Analyzer |
| 109990076 | SARK-110 Antenna Analyzer |
| 114992364 | Raspberry Pi Compute Module 4/5 Antenna Kit |
| 318020610 | External Antenna 915MHZ-Black;RPSMA-J-L195mm |
| 318020611 | LoRa Fiberglass Antenna, 858-878MHz, 8dBi, 1300mm |
| 318020612 | LoRa Fiberglass Antenna, 860-930MHz, 5dBi, 600mm |
| 318020613 | LoRa Fiberglass Antenna, 900-930MHz, 7dBi, 920mm |
| 321990855 | Fiberglass Antenna Magnetic Base; N Female to RP-SMA male – CFD200 2m Cable – Black |
| 321990397 | SMA to I-PEX Antenna Cable – 120mm |
| 318020269 | 2.8dBi LoRa Antenna – SMA male – 868MHz – 195mm |
| 318020389 | 2.6dBi LoRa Antenna – SMA male – 915MHz – 195mm |
| 318020652 | Fiberglass Antenna Kit; 902-928MHz-3dBi with Antenna Base for Long Range Application |
| 318020628 | External Antenna 868MHZ-2.8dBi;RPSMA Male-L195mm |
| 318020690 | LoRa Fiberglass Antenna Kit For Helium; 863-870MHz; 5.8dBi; 800mm; RF Explorer RFELA-2/58X |
| 318020691 | LoRa Fiberglass Antenna Kit For Helium; 902-928MHz; 5.8dBi; 800mm; RF Explorer RFELA-3/58X |
| 318020692 | LoRa Fiberglass Antenna Kit; 863-870MHz; 8dBi; 1300mm; RF Explorer RFELA-4/88X |
| 318020693 | LoRa Fiberglass Antenna Kit; 902-928MHz; 8dBi; 1300mm; RF Explorer RFELA-5/8X9 |
| 306050590 | RF Explorer RFEA-1 External Lightning Arrestor; 3GHz; N Male/Female Connector |
| 318020708 | LoRa Fiberglass Antenna Kit with base; 860-930MHz-3dBi-360mm; RFELA-1/389 |
| 321990838 | External Antenna |
| 110991765 | Long Range Indoor Antenna Kit; 860-930MHz; 3dBi; 295mm |
| 103990623 | 2.4GHz Rod Antenna (2.81dBi) for Seeed Studio XIAO |
| 110061501 | LoRa Antenna Kit for Wio-WM1302 LoRaWAN Gateway Module |
| 110061502 | 4G Antenna Kit for LTE Cat 4 EC25 mini-PCIe |
| 110061521 | GPS Antenna Kit |
| 113070002 | External Antenna 868-915MHZ-2dBi;SMA-L195mm-Foldable |
| 109990545 | External Antenna for RF Explorer®️Pro; 4dBi 5G Rod Antenna-support 900MHz-6GHz |
| 318020748 | 2.4GHz FPC Antenna (2.9dBi) for Seeed Studio XIAO ESP32-C3 |
| 114993587 | 2.4G/5G External Antenna with RP-SMA Male Connector and 1.13 Coaxial Cable 130mm Set |
| 318020968 | 2.4GHz FPC Antenna (1.16dBi) for XIAO ESP32-S3 |
| 100039813 | 2.4GHz FPC Antenna (1.86dBi) for XIAO nRF54L15 |
| 101020073 | Grove – Electromagnet |
| 311070006 | Magnetic Door Switch |
| 111990004 | G1&2 Electric Solenoid Valve (Normally Closed) |
| 101990921 | LDS02 LoRaWAN Door & Window Sensor Alarm – EU868MHz, Smart Home, Wireless, OTAA, Home Security |
| 101990922 | LDS02 LoRaWAN Door & Window Sensor Alarm – US915MHz, Smart Home, Wireless, OTAA, Home Security |
| 321010822 | SenseCAP T1000 Magnetic USB Type-A to 2P Charging Cable – White, 1000mm |
| 101991403 | SONOFF SNZB-04P Zigbee Door/Window Sensor – Home Assistant Compatible |
| 109020021 | Grove – Doppler Radar (BGT24LTR11) – 24GHz Transceiver |
| 114992118 | Millimeter Wave Doppler Radar (SYH24A1) – 24GHz Transceiver |
| 101990883 | 24GHz mmWave Sensor – Human Stationary Presence Module |
| 101990884 | 24GHz mmWave Sensor – Fall Detection Module |
| 101990886 | MR60BHA1 60GHz mmWave Module – Respiratory Heartbeat Detection | FMCW | Sync Sense | Privacy Protect |
| 101990885 | MR24BSD1 24GHz mmWave Sensor – Respiratory Sleep Detection Module | Doppler radar | Sync Sense | Privacy Protect |
| 101990981 | MR60FDA1 60GHz mmWave Sensor – Fall Detection Pro Module | FMCW, Sync Sense, Privacy Protect, high stability, support secondary development |
| 101991030 | 24GHz mmWave Sensor – Human Static Presence Module Lite – human presence, FMCW, Configurable Underlying Parameter, Arduino support, Home Assistant, ESPHome |
| 114992995 | CEM5855H 24GHz mmWave Radar Sensor-Human Stationary Presence Module- Ideal for Home Assistance |
| 101991222 | MR60FDA2 60GHz mmWave Sensor – Fall Detection Module |
| 101991221 | MR60BHA2 60GHz mmWave Sensor – Breathing and Heartbeat Module |
| 114993300 | Everything Presence Lite |
| 114993387 | XIAO 60GHz mmWave Human Breathing and Heartbeat Sensor -MR60BHA2 |
| 114993388 | XIAO 60GHz mmWave Human Fall Detection Sensor-MR60FDA2 |
| 102990824 | Wio Tracker – GPS, BT3.0, GSM, Arduino Compatible |
| 317030213 | MDBT42Q – nRF52832 based BLE module |
| 113990597 | Particle Argon IoT Development Board (Wifi+Mesh+Bluetooth) |
| 113990599 | Particle Xenon IoT Development Board (Mesh+Bluetooth) |
| 113990598 | Particle Boron IoT Development Board (Cellular+Mesh+Bluetooth) |
| 102991135 | ARDUINO MKR GSM 1400 |
| 102991139 | ARDUINO MKR WiFi 1010 |
| 113990614 | W600 Module |
| 317060362 | MT3620 Module(AI-Link WF-M620-RSC1) |
| 113020031 | Grove – W600 |
| 113990582 | MDBT50Q-1MV2 nRF52840 Based BLE Module |
| 113990583 | MDBT50Q-P1M nRF52840 Based BLE Module |
| 113990584 | MDBT50Q-U1M nRF52840 Based BLE Module |
| 113020004 | Grove – XBee Carrier |
| 317030026 | MDBT40-256RV3 nRF51822 based BLE module |
| 113030019 | Blueseeed Shield V2 (HM01) |
| 113990436 | 13.56Mhz RFID Module (Embedded PCB Antenna) |
| 113060007 | Grove – LoRa Radio 433MHz |
| 113060006 | Grove – LoRa Radio 868MHz |
| 113990111 | LoNet 800L – Mini GSM&GPRS Breakout |
| 317990024 | 2.4G WIRELESS MODULE NRF24L01+PA |
| 113030001 | NFC Shield V2.0 |
| 113990577 | Air602 WiFi Development Board |
| 113100002 | ROCK Pi Wireless Module A1- Wireless 2.4G, 36Mbps/BlueWireless 4.2 |
| 113100003 | ROCK Pi Wireless Module A2- Wireless 2.4G&5G, 200Mbps/BlueWireless 5.0 |
| 113100004 | ROCK Pi Wireless Module A3- Wireless 2.4G&5G, 400Mbps/BlueWireless 5.0, Support RSDB |
| 113990414 | EMW3239 Combo Module-WiFi Bluetooth BLE |
| 113990416 | EMW3166 WiFi Module |
| 113990576 | Air602 WiFi Module |
| 106990004 | Wireless Charging Module |
| 106990017 | Wireless Charging Module – 5V&1A |
| 106990018 | Wireless Charging PCB Module 5-12V |
| 113990556 | nRF52840 Module with Ceramic Antenna |
| 113990578 | ESP32-S Wi-Fi+BT SoC Module (IPEX block output) |
| 113990579 | ESP32-A1S Wi-Fi SoC Audio Module (IPEX block output) |
| 109990246 | YARD Stick One |
| 102110419 | Realtek RTL8720DN 2.4G/5G Dual Bands Wireless and BLE5.0 Combo Module |
| 113990194 | Dragino Long Range Shield – support 433M frequency |
| 114990395 | The AirBoard – prototyping platform For IoT |
| 114990655 | Crazyflie 2.0 DWM1000 Loco Positioning Deck for Indoor Positioning System |
| 109990165 | RFM98 Ultra-long Range Transceiver Module – LoRa Module – Support 433M Frequency |
| 113990017 | 315Mhz RF link kit |
| 113990042 | Mini 125Khz RFID Module – Pre-Soldered Antenna (35mm Reading Distance) |
| 113990018 | 2KM Long Range RF link kits with encoder and decoder |
| 114990002 | Mesh Bee – Open Source Zigbee Pro Module with MCU (JN5168) |
| 113990039 | 433Mhz Wireless Serial Transceiver Module – 1 Kilometer |
| 113990636 | EMW3060 WiFi Module |
| 113990634 | EMW5080V2 5V WiFi Module |
| 113990635 | EMW110 WiFi Module |
| 113990637 | EMB1061 BLE Module |
| 103100001 | UartSBee V5 |
| 113030016 | RS232 Shield |
| 102990965 | Seeedstudio ESP8285 Wi-Fi SoC Module |
| 113990294 | RTL8710 WiFi Module |
| 102991141 | ARDUINO MKR1000 |
| 109110002 | WiPy 2.0 |
| 113990010 | 433Mhz RF link kit |
| 109990038 | 1Sheeld – Replace your Arduino shields with smartphone |
| 114992269 | Realtek RTL8720DN 2.4G/5G Dual Bands with U.FL Style Connector |
| 113990856 | Quectel EM06-E LTE Cat 6 M.2 Module – ODYSSEY X86J4105 Compatible |
| 113050013 | Blueseeed Bee (Dual model) |
| 113020000 | Grove – Serial RF Pro |
| 113020001 | Grove – 315MHz Simple RF Link Kit |
| 113030008 | Wifi Shield V2.0 |
| 113050002 | RFbee V1.1 – Wireless arduino compatible node |
| 113990418 | EMW3080(BE) WiFi Module |
| 113990814 | HM-BT4502 Bluetooth Low Energy (BLE) Pass-through Module |
| 113020008 | Grove – Serial Blueseeed(CSR BC417) |
| 113990819 | LSN50-V2 — Waterproof Long Range Wireless LoRa Sensor Node – Support 433MHz Frequency |
| 113990820 | Dragino LSN50-V2 — Waterproof Long Range Wireless LoRa Sensor Node – Support 868MHz Frequency |
| 113020002 | Grove – 125KHz RFID Reader |
| 109990042 | Batteries for Electric Tracker |
| 113990234 | Wio Core |
| 113990816 | Wio Core (ESP8266 ESP-WROOM-02),4MB flash |
| 114990229 | PhoBot |
| 102991015 | LTE Cat 1 Pi HAT (USA – AT&T) |
| 113990454 | LTE Cat 1 Pi HAT (USA – VZW) |
| 113990496 | LTE Cat 1 Pi HAT (Europe) |
| 113990663 | MT7688AN BIT3.1 Module |
| 317060162 | AI7688H |
| 113990854 | Quectel EM06-A LTE Cat 6 M.2 Module – ODYSSEY X86J4105 Compatible |
| 113990014 | 125Khz RFID module – UART |
| 114990112 | Crazyradio PA – long range 2.4Ghz USB radio dongle with antenna |
| 113020009 | Grove – Blueseeed – Dual model (HM13) |
| 110040002 | RePhone Kit Create |
| 113050012 | Seeed nRF51822 Module |
| 317030001 | CSR HM-11 Module |
| 317030014 | SMD Nordic nRF51822 Module with 2.4GHz;16*28mm( with PCB antenna) |
| 113990417 | EMW3166 WiFi Module(External IPEX antenna) |
| 101990071 | EMW3162 WiFi Module (External IPEX antenna) |
| 113990855 | Quectel EM05-E LTE Cat 4 M.2 Module – ODYSSEY X86J4105 Compatible |
| 113990088 | WireLess Gate Shield |
| 113990089 | EMW3162 WiFi Module |
| 317070463 | Mini PCIe LoRa Gateway Module RAK2247-SPI-868MHz |
| 317070464 | Mini PCIe LoRa Gateway Module RAK2247-SPI-915MHz |
| 114991092 | RTL8710AF WiFi Board |
| 103990038 | DevDuino Sensor Node V1.3 (ATmega 328) – RC2032 battery holder |
| 317060262 | P1 – Particle Wi-Fi Module with Antenna |
| 317060019 | WT8266-S1 FCC&CE&RoHS& Wi-Fi Module based on ESP8266 |
| 317990029 | M328W – wireless Internet of Things module |
| 317060009 | LinkIt Connect 7681 Module – Scale for Wi-Fi solution |
| 113990100 | LinkIt Connect 7681 – Wi-Fi HDK for IoT |
| 317030016 | 2.4GHz Bluetooth Low Energy 4.0 module-4dB V-13051 |
| 317030018 | 2.4GHz Nordic nRF51822 Low Energy 4.0 module-20dB V-14004 |
| 113990016 | 802.11b&g&n 150Mbps Wireless USB Adapter |
| 110990471 | Raspberry Pi Media Center Kit |
| 113010001 | Arch GPRS V2 |
| 114992470 | MT7628NN Development Board – With OpenWrt Linux and 2T2R Wi-Fi |
| 113020091 | Grove-Wio-E5 Wireless Module – STM32WLE5JC, ARM Cortex-M4 and SX126x embedded, supports LoRaWAN on EU868 & US915 |
| 113990939 | Wio-E5 mini Dev Board – STM32WLE5JC, ARM Cortex-M4 and SX126x embedded, supports LoRaWAN on EU868 & US915 |
| 114992549 | WM1302 LoRaWAN Gateway Module (SPI) – EU868, based on LoRa Concentrator Semtech SX1302 |
| 113990974 | EMB1082 BLE Module – Support MXMESH |
| 113990975 | EMC3080 WI-FI&BLE Module – Support MXMESH |
| 114992733 | Superheterodyne wireless transceiver module-433MHz |
| 109990505 | M5313 – NB-IoT |
| 113990080 | WiFi Serial Transceiver Module Breakout Board w& ESP8266 |
| 114992732 | RF Transmitter and Receiver Link Kit – 433MHz |
| 113991014 | EMB1061 BLE Module -p – Tape&Reel |
| 113990076 | Xbee Pro RF Modules 928MHz 200Kbps 20-Pin w& Cortex-M3 EFM32G230 @28MHz – XBP9B-DMWT-022 |
| 114992994 | Home Assistant Connect ZBT-1 |
| 113991082 | Sonoff Zigbee 3.0 USB Dongle Plus–ZBDongle-E- Home Assistant Compatible |
| 317060562 | MT7628N-A WIFI Module, 128MB RAM 32MB FLASH, supports OpenWRT |
| 114993067 | Crazyradio 2.0 –2.4GHz ISM Band Radio, USB-A connector, Antenna |
| 113991134 | LTE Cat 4 EC25-AFXGA-mini-PCIe – 2G/3G/4G communication, built-in multiple GNSS, North American operators |
| 113991135 | LTE Cat 4 EC25-EUX-mini-PCIe – 2G/3G/4G communication, built-in multiple GNSS, EMEA and Thai operators supported |
| 114992865 | Wio-WM1110 Wireless Module – Semtech LR1110 and Nordic nRF52840 |
| 114993082 | Wio-WM1110 Dev Kit, built-in Semtech LR1110 and Nordic nRF52840 |
| 101021093 | Grove – NFC (ST25DV64), ST25DV64K Chip, Versatile NFC/RFID tag board, 3.3V/5V power supply |
| 114993120 | Wio-E5-LE Wireless Module (Bulk) – STM32WLE5JC, ARM Cortex-M4 and SX126x embedded, supports LoRaWAN on EU868 & US915 |
| 114993121 | Wio-E5-LE Wireless Module (Tape Reel) – STM32WLE5JC, ARM Cortex-M4 and SX126x embedded, supports LoRaWAN on EU868 & US915 |
| 113991214 | LTE Cat 4 EC25-EFA-mini-PCIe – 2G/3G/4G communication, built-in multiple GNSS, EMEA/Korea/Thailand/India operators |
| 317990887 | LoRa Wireless Module-28P,LF band(470MHz/434MHz),L12*W12*H2.5mm |
| 113991234 | LTE Cat 4 EC25-EMGA-mini-PCIe – 2G/3G/4G communication, built-in multiple GNSS, EMEA/Southeast Asia operators |
| 109100021 | L76K GNSS Module for Seeed Studio XIAO |
| 113991174 | LTE Cat 4 EC25-AUXGR-mini-PCIe – 2G/3G/4G communication, built-in multiple GNSS, Latin America and Australia and New Zealand operators |
| 113991296 | LTE Cat 4 EC25-JFA-mini-PCIe – 2G/3G/4G communication, built-in multiple GNSS, Japan operators |
| 110992005 | Mini-PCIe USB Zigbee Module |
| 114993390 | Wio-SX1262 Wireless Module (Tape Reel), SX1262 embedded, supports LoRa&LoRaWAN on EU868 & US915 |
| 114993556 | RTL8822CE Wireless NIC, 2.4G/5GHz Dual-Band WiFi 5, Bluetooth 5.0, Compatible with Jetson Orin |
| 113991155 | BeagleBoard BM3301-1313 |
| 113991154 | BeagleBoard BM3301-1216 |
| 109990565 | Wio-WM6108 Wi-Fi HaLow mini-PCIe Module |
| 110992144 | Home Assistant Connect ZWA-2 |
| 113991415 | Wio-LR1121 Wireless Module with IPEX (Tape Reel), LR1121 embedded, supports sub-GHz, 2.4GHz ISM, and 2.1GHz satellite S-band |
| 114993669 | Home Assistant Connect ZBT-2 |
| 109990225 | LoRa Antenna Kit |
| 317060016 | WiFi Serial Transceiver Module w& ESP8266 – 1MB Flash |
| 102991334 | Seeed IoT Button for AWS – Cloud Programmable Dash Button |
| 317060010 | LinkIt MT5931 Module -Scale for Wi-Fi module |
| 113990976 | EMW3090V2 WI-FI Module |
| 317060522 | WiFi Module(M.2 E-Key) |
| 102991715 | Ai-WB2-32S-Kit-BL602 based Wi-Fi&Bluetooth5 module with onboard antenna and 4MByte Flash, Ideal for mobile devices, Smart Home |
| 109100041 | Wi-Fi HaLow Transceiver for Seeed Studio XIAO |
| 102991074 | Pixy2 CMUcam5 – Smart Vision Sensor – Object Tracking Camera for Arduino, Raspberry Pi |
| 101990260 | Optor Cam2pc Visual-Inertial SLAM |
| 102110157 | Intel Movidius MA245X AI Kit Compatible w/ Intel Movidius Stick |
| 101990640 | MU VISION SENSOR 3 – AI Robot Vision Camera Supported by Arduino & Micro: Bit |
| 101990962 | SenseCAP A1101 – LoRaWAN Vision AI Sensor, Open the Door to the TinyML world |
| 114992866 | Grove – Vision AI Module with Himax HX6537-A processor, thumb-size AI-powered OV2640 camera sensor, support YOLO v5 and Edge Impulse |
| 101021112 | Grove – Vision AI Module V2 – Arm Cortex-M55 & Ethos-U55, TensorFlow and PyTorch supported, Arduino, Raspberry Pi, Seeed Studio XIAO, ESP-based dev board compatible |
| 113991315 | SenseCAP Watcher W1-A Clear Enclosure – The Physical AI Agent for Smarter Spaces |
| 113991275 | SenseCAP Watcher W1-B White Enclosure – The Physical AI Agent for Smarter Spaces |
| 102991894 | reCamera 2002 8GB – Open Source AI Camera |
| 102991895 | reCamera 2002 64GB – Open Source AI Camera |
| 102991896 | reCamera 2002w 8GB – Open Source AI Camera |
| 102991897 | reCamera 2002w 64GB – Open Source AI Camera |
| 110061621 | Seeed Grove Vision AI V2 Kit for ARM |
| 110992084 | Seeed Studio Modbus RS485 Vision AI Camera |
| 101991343 | SenseCAP A1102 – LoRaWAN Vision AI Sensor |
| 114993645 | AI Assistant | STM32N6 AI Development Kit with Global Shutter Camera |
| 104990982 | XIAO Vision AI Camera |
| 101020010 | Grove – Ultrasonic Distance Sensor |
| 101990480 | ThoneFlow-3901UY UART Serial Version PMW3901 Optical Flow Sensor |
| 114991550 | Crazyflie Z-ranger v2 deck |
| 101020533 | Grove – Digital Distance Interrupter 0.5 to 5cm(GP2Y0D805Z0F) |
| 101020578 | Grove – Digital Distance Interrupter 0.5 to 5cm(GP2Y0D805Z0F)(P) |
| 114991485 | Crazyflie2.x Multi-ranger deck Based on VL53L1x ToF Sensor,Laser Ranging Module for The Drone |
| 101020532 | Grove – Time of Flight Distance Sensor(VL53L0X) – (ToF) laser-ranging module,Long Range Precision ranging |
| 101020175 | Grove – IR Distance Interrupter v1.2 |
| 101990340 | HPS-167 ToF Infrared Distance Measuring sensor(0.08-35m) |
| 101990656 | TF-Luna LiDAR Module – Short-Range Distance Sensor |
| 101990388 | TFmini Plus – ToF LIDAR Range Finder |
| 101991041 | RS485 750cm Ultrasonic Level Sensor |
| 101991042 | RS485 500cm Ultrasonic Level Sensor |
| 101021097 | Grove – Ultrasonic Sensor (US5) – ToF, distance detection, echo energy intensity value, materials distinguished, 1.6cm in diameter, 1.2cm in heigh |
| 101020052 | Grove – GSR sensor |
| 101020083 | Grove – Gesture(PAJ7620U2) |
| 114991549 | Crazyflie 2.X-Flow v2 deck with tof sensor, optical flaw, gps module |
| 101990651 | Dragino LoRaWAN Water Leak Sensor – EU868MHz |
| 101990652 | Dragino LoRaWAN Water Leak Sensor – US915MHz |
| 101990078 | Raspberry Pi Sense HAT – Make your own Astro-Pi |
| 101990653 | Dragino LoRaWAN Door Sensor – EU868MHz |
| 101990654 | Dragino LoRaWAN Door Sensor – US915MHz |
| 101020341 | Grove – I2C Color Sensor V2:RGB LED Control |
| 114020121 | Grove – 3-Axis Digital Accelerometer (LIS3DHTR) |
| 101020047 | Grove – I2C Touch Sensor |
| 114991396 | Flick Zero – 3D Tracking & Gesture pHAT for Raspberry Pi Zero |
| 114991398 | Flick Large – Standalone 3D Tracking and Gesture Breakout |
| 114991397 | Flick HAT – 3D Tracking & Gesture HAT for Raspberry Pi |
| 101020552 | Grove – Capacitive Touch Slider Sensor (CY8C4014LQI) |
| 101020534 | Grove – 12 Key Capacitive I2C Touch Sensor V2 (MPR121) |
| 101020636 | Grove – 12-Channel Capacitive Touch Keypad (ATtiny1616) |
| 101020037 | Grove – Touch Sensor |
| 101990560 | Astra Embedded S – Next Generation Structured Light 3D Camera |
| 101990620 | TFmini S LiDAR module – Short-Range ToF LIDAR Range Finder |
| 101110021 | DepthEye Slim – VGA ToF Camera with Sony IMX556PLR DepthSense™ |
| 101110022 | DepthEye Cube |
| 101020599 | Grove – 2-Channel Inductive Sensor (LDC1612) |
| 114990093 | Weight Sensor (Load Cell) 0-3kg |
| 314990000 | Weight Sensor (Load Cell) 0-500g |
| 314030003 | Load Sensor |
| 101020051 | Grove – ADXL335- 3-Axis Analog Accelerometer (±3g) |
| 101020252 | Grove – IMU 10DOF v2.0 (MPU9250) |
| 101020173 | Grove – Light Sensor (P) v1.1 – LS06-S Phototransistor Compatible with Arduino |
| 101020580 | Grove – Light&Color&Proximity Sensor (TMG39931) – Color sense,light detection,Bar Code Emulation |
| 101020076 | Grove – Luminance Sensor |
| 101020060 | PIR Motion Sensor – Large Lens version |
| 101020554 | Grove – Human Presence Sensor (AK9753) |
| 101020617 | Grove – Adjustable PIR Motion Sensor |
| 101020174 | Grove – Infrared Reflective Sensor v1.2 |
| 114020141 | Grove – Thermal Imaging Camera / IR Array MLX90640 55 degree |
| 114020142 | Grove – Thermal Imaging Camera / IR Array MLX90640 110 degree |
| 101020049 | Grove – Flame Sensor, YG1006 sensor with high speed of 15 μS/cm & high sensitivity-ideal for Fire Alarm System |
| 101020046 | Grove – Hall Sensor |
| 105020012 | Grove – 6-Axis Accelerometer&Gyroscope |
| 101020039 | Grove – 3-Axis Digital Accelerometer(±1.5g) |
| 101020582 | Grove – 3-Axis Digital Accelerometer ±16g Ultra-low Power (BMA400) |
| 101020584 | Grove – 6-Axis Accelerometer&Gyroscope (BMI088) |
| 101020587 | Grove – Optical Rotary Encoder(TCUT1600X01) |
| 101020632 | Grove – 3-Axis Digital Accelerometer ±200g (ADXL372) |
| 101020633 | Grove – Single Axis Analog Accelerometer ±100g (ADXL1001) |
| 101020637 | Grove – 3-Axis Analog Accelerometer ±20g (ADXL356B) |
| 101020638 | Grove – 3-Axis Analog Accelerometer ±40g (ADXL356C) |
| 101020639 | Grove – 3-Axis Digital Accelerometer ±40g (ADXL357) |
| 101020672 | Grove – 6-Axis Digital Accelerometer&Gyroscope ±40g (ADIS16470) |
| 101020071 | Grove – 3-Axis Digital Accelerometer(±400g) |
| 114991731 | SenseCAP Wireless Light Intensity Sensor – LoRaWAN US915MHz |
| 114991727 | SenseCAP Wireless Light Intensity Sensor – LoRaWAN EU868MHz |
| 113990020 | PIR Motion sensor module |
| 101020020 | Grove – PIR Motion Sensor-Low-cost&Easy-to -use motion detector-beginners friendly |
| 101020892 | Grove – Thermal Imaging Camera – MLX90641 BCA 16×12 IR Array with 110° FOV |
| 101020063 | Grove-Loudness Sensor-Based on amplifier LM2904&built-in microphone |
| 101020023 | Grove – Sound Sensor Based on LM358 amplifier – Arduino Compatible |
| 101020172 | Grove – Line Finder v1.1 |
| 101020030 | Grove – Digital Light Sensor – TSL2561 for Arduino Compatible |
| 101020089 | Grove – Sunlight sensor (visible light and infrared light) – SI1151 |
| 101020132 | Grove – Light Sensor v1.2 – LS06-S Phototransistor Compatible with Arduino |
| 101020014 | Grove – Light Sensor |
| 102990763 | OpenMV Cam M7 |
| 114991702 | Sipeed MAIX Binocular Camera for Dock/Go/Bit |
| 110991167 | Pan/Tilt2 Servo Motor Kit for Pixy2 – Dual Axis Robotic Camera Mount |
| 114991684 | Sipeed MAIX-I module WiFi version ( 1st RISC-V 64 AI Module, K210 inside ) |
| 114991695 | Sipeed MAIX-I module w/o WiFi ( 1st RISC-V 64 AI Module, K210 inside ) |
| 101020025 | Grove – Tilt Switch |
| 114991072 | Crazyflie 2.0 Z-ranger deck board |
| 102990649 | High-Sensitivity Pulse Oximeter and Heart-Rate Sensor for Wearable Health- based on heart-rate/SpO2 sensor (MAX30102)-Low-Power&High-Intergration |
| 103020016 | Grove – Differential Amplifier |
| 101090001 | MAKER LINE – Simplifying Line Sensor (PIC16F1827) |
| 314070001 | Piezo Vibration Sensor |
| 314070000 | Shop GPRS Shield V3.0 at Seeed Studio, offering wide selection of electronic modules for makers to DIY projects. Quality Guarantees. Lifetime Tech Support. Full Tutorials and Projects. |
| 101020069 | Grove-Q Touch Sensor |
| 101020232 | Grove – Speech Recognizer |
| 114991252 | Flow Breakout Board |
| 101020353 | Grove – mini PIR motion sensor |
| 101020081 | Grove – 6-Axis Accelerometer&Compass v2.0 |
| 101020793 | Grove – Digital PIR Motion Sensor(12m) |
| 101020005 | Grove – Collision Sensor |
| 101020586 | Grove – Vibration Sensor (SW-420) |
| 101020054 | Grove – ADXL345 – 3-Axis Digital Accelerometer(±16g) |
| 101020016 | Grove – IR (Infrared) Receiver |
| 101020043 | Grove – GUVA-S12D UV Sensor |
| 101020600 | Grove – I2C UV light Sensor – VEML6070 |
| 103020024 | Grove – Finger-clip Heart Rate Sensor |
| 101990052 | Tessel IR Module |
| 101020031 | Grove – Piezo Vibration Sensor |
| 101020613 | Grove – Laser PM2.5 Dust Sensor – Arduino Compatible – HM3301 |
| 101020012 | Grove – Dust Sensor(PPD42NS) – measuring PM 2.5,dual PWM output |
| 101020312 | Grove – Heelight Sensor |
| 101020082 | Grove – Finger-clip Heart Rate Sensor with shell |
| 101020713 | Grove – Capacitive Fingerprint Scanner/Sensor |
| 101020057 | Grove – Fingerprint Sensor |
| 101020058 | Grove – EMG Detector |
| 101990386 | HPS-3D160-U Solid-State LiDAR |
| 114991984 | Slamtec Mapper M1M1 ToF Laser Scanner Kit – 20M Range |
| 101990280 | Pysense |
| 109990326 | Welle – A Smart Interface Controller |
| 101990440 | PSK-CM8JL65-CC5 ToF Infrared Distance Measuring Sensor |
| 114991133 | DE-LIDAR TF02 |
| 114990070 | Motor Speed Sensor Module |
| 109990325 | Solid State TOF LiDAR – CE30-A |
| 101990641 | Slamtec Mapper M2M2 – LiDAR Mapping Sensor(Industrial Grade) – 40M Range |
| 110991066 | RPLiDAR A2M8 360 Degree Laser Scanner Kit – 12M Range |
| 110991067 | RPLiDAR A2M6 360 Degree Laser Scanner Kit – 18M Range |
| 110991068 | RPLiDAR A3M1 360° Laser Scanner Kit – 25M Range |
| 114090021 | RPLiDAR S1 Portable ToF Laser Scanner Kit – 40M Range |
| 110991065 | RPLiDAR A1M8 360 Degree Laser Scanner Kit – 12M Range |
| 101990580 | Microwave Sensor – 5.8GHz Doppler Radar Motion Sensor – MW0582TR11 |
| 101020080 | Grove – IMU 9DOF v2.0 |
| 101020033 | Grove – Ear-clip/Finger-clip Heart Rate Sensor |
| 114990100 | Weight Sensor (Load Cell) 0-50kg |
| 101020893 | Grove – Thermal Imaging Camera – MLX90621 BAA 16×4 IR Array with 25° FOV |
| 101020894 | Grove – Single-Point Infrared Thermometer – MLX90614 DCI with 5° FOV |
| 101020895 | Grove – Single-Point Infrared Thermometer – MLX90614 DCC with 35° FOV |
| 114992327 | Keepa – Social Distance Habit Trainer / Social Distancing Wristband for Children, Bulit-in ultrasonic sensor, 3 Alert Modes, Switchable Alert Distance |
| 101990702 | TOFSense – Time of Flight Laser Ranging Sensor |
| 101020872 | Grove – 12 Key Capacitive I2C Touch Sensor V3 (MPR121) |
| 114992561 | RPLiDAR A1M8-R6 360° Laser Scanner Kit – 12M Range |
| 101990661 | SenseCAP ORCH S4 4-In-1 Weather Sensors (A1A), Air Temperature/Humidity/Atmospheric Pressure/Light |
| 314990733 | Industrial PAR Sensor (S-PAR-02A), MODBUS-RTU RS485 |
| 314990734 | Industrial PAR Sensor (PAR-2.5V), supporting analog 0~2.5V output |
| 314990735 | Industrial PAR Sensor (S-PAR-02B) MODBUS-RTU RS485, with Waterproof Aviation Connector |
| 114992584 | SenseCAP Wireless Light Intensity Sensor- LoRaWAN AS923 MHz |
| 114992170 | SenseCAP Sensor Hub 4G Data Logger – with built-in rechargeable battery version |
| 101990662 | SenseCAP ORCH S4 4-In-1 Weather Sensors (A1B), Air Temperature/Humidity/Atmospheric Pressure/Light – with waterproof aviation connector |
| 314990739 | Industrial Light Intensity Sensor, MODBUS-RTU RS485 &0-2V (S-Light-01) |
| 314990740 | Industrial Light Intensity Sensor, MODBUS-RTU RS485 &0-2V (S-Light-02), with Waterproof Aviation Connector |
| 114992171 | Sensor Hub Industrial-grade 4G Data Logger with MODBUS-RTU RS485 protocol – DC Only |
| 206001060 | Industrial IP68 Modbus RS485 1-to-4 Splitter/Hub (to be used w/ SenseCAP Sensor Hub) |
| 114992602 | Percipio 3D Camera – FM851-GI-E1 |
| 101060003 | TF03-180 LiDAR – Industrial-Grade Long Range Distance Sensor (180m) |
| 101060004 | TF03-100 LiDAR – Industrial-Grade Long Range Distance Sensor (100m) |
| 101090022 | TFmini-i LiDAR – Distance Sensor (12m) with CAN Interface |
| 101090021 | TF02-i LiDAR – Distance Sensor (40m) with CAN Interface |
| 101990693 | SenseCAP ONE S500 5-in-1 Compact Weather Sensor |
| 114992649 | SenseCAP Wireless Light Intensity Sensor – LoRaWAN AU915 MHz |
| 101990784 | SenseCAP ONE S900 9-in-1 Compact Weather Sensor |
| 101990787 | SenseCAP ONE S700 7-in-1 Compact Weather Sensor |
| 114992738 | RPLiDAR S2 Low Cost 360° Laser Range Scanner – 30M Range |
| 110060707 | Particle Sensor Kit 3G (Eur/Afr/Asia): Components for a sample product, 10 Sensors, Particle SIM Card with Service in 100+ Countries |
| 114992753 | OakSense H67V-VGA resolution TOF camera supported C++ and Python |
| 114992757 | OakSense H60Q-QVGA resolution ToF camera – 3D camera – supported C++ and Python |
| 101020992 | Grove – Thermal Imaging Camera – MLX90641 BCB 16×12 IR Array with 55° FOV |
| 101020993 | Grove – Thermal Imaging Camera – MLX90621 BAB 16×4 IR Array with 60° FOV |
| 114992777 | Wio Terminal LoRaWAN Field Tester Kit: Plug and Play LongFi Network Monitor for Helium Network |
| 101990942 | LWL02 LoRaWAN Water Leak Sensor – US915MHz, Smart home, OTTA, Wireless |
| 101990941 | LWL02 LoRaWAN Water Leak Sensor – EU868MHz, Smart home, OTTA, Wireless |
| 114992868 | SenseCAP S2102 – LoRaWAN Wireless Light Intensity Sensor |
| 114992869 | SenseCAP S2103 LoRaWAN® CO2, Temperature, and Humidity Sensor for Outdoor&Indoor Air Quality, CO2 Meter, Carbon Emission |
| 101990902 | SenseCAP S1000 10-in-1 Compact Weather Sensor with CO2 Measurement |
| 101990963 | SenseCAP A1102 – LoRaWAN Sound/Vibration AI Sensor |
| 101021013 | Grove – SEN54 All-in-one environmental sensor – VOC, RH, Temp, PM1.0/2.5/4/10 with proprietary algorithms, HVAC, Air Purifier |
| 101021014 | Grove – SEN55 All-in-one environmental sensor – NOx, VOC, RH, Temp, PM1.0/2.5/4/10 with proprietary algorithms, HVAC, Air Purifier |
| 101991001 | H2 Helium-LoRaWAN Weather Station WS2001 |
| 101990961 | SenseCAP S2120 8-in-1 LoRaWAN Weather Sensor |
| 110991807 | SenseCAP ONE Mounting Bracket Flange,Fixed Support |
| 114110128 | RPLiDAR A2M12 360 Degree Laser Scanner Kit – 12M Range |
| 101110081 | RPLiDAR S2L 360 Degree Laser Range Scanner – 18M Range, 2D point cloud map, 80000 lux light resistance, IP65, high safety for human eye |
| 101110082 | RPLiDAR S2E 360 Degree Laser Range Scanner – 30M Range, 2D point cloud map, 80000 lux light resistance, IP65, high safety for human eye |
| 113991076 | Sonoff DW2-WiFi Wireless Smart Door/Window Sensor, Smart home, Bluetooth pairing |
| 113991079 | Sonoff SNZB-03-Zigbee Motion Sensor, Smart home security, Indoor motion detector, Low-cos |
| 113991080 | Sonoff SNZB-04 Zigbee Wireless Smart Door/Window Sensor, Smart home,Voice control |
| 114992990 | Wio Terminal Helium Monitor Kit: plug-and-play hotspot monitor for helium network |
| 114993027 | Sipeed MaixSense A010 with LCD screen – 3D Sensor Module Based on BL702 and TOF Camera |
| 101991021 | SenseCAP S500 V2 5-in-1 Compact Weather Station |
| 101991022 | SenseCAP S700 V2 7-in-1 Compact Weather Sensor |
| 101991023 | SenseCAP S800 8-in-1 Compact Weather Sensor |
| 101991024 | SenseCAP S1000 V2 10-in-1 Compact Weather Sensor |
| 101991025 | SenseCAP S1000 10-in-1 Compact Weather Station -Carbon Monitoring |
| 101991047 | Industrial Total Solar Radiation Sensor MODBUS-RTU RS485, Solar Radiation Meter |
| 101991048 | Industrial UV Radiation Sensor MODBUS-RTU RS485, Ultraviolet Radiation Meter |
| 114993073 | SenseCAP T1000-A LoRaWAN Tracker for Indoor and Outdoor Positioning |
| 114993107 | SenseCAP Card Tracker T1000-C |
| 101021096 | Grove – D7S Vibration Sensor – real-time earthquake detect, I2C, Low Power Consumption |
| 101991067 | Grove Smart IR Gesture Sensor, infrared camera sensor, AI algorithm, over 15 gestures detection, I2C, SPI, support Grove, XIAO, Type-C connecting, 3.3V/5V |
| 101090041 | RPLiDAR S3 – 40m range, 2D point cloud map, 32KHz sampling, 0.1125° angular resolution, 80000 lux light resistance, IP65, high safety for human eye |
| 101990793 | Industrial Turbidity Sensor MODBUS-RTU RS485 for Water Quality Monitoring |
| 101991101 | RS485 Air Temperature, Humidity and Barometric Pressure Sensor(S-THP-01A) |
| 114993207 | Card Tracker White Label T1000-A |
| 101090061 | RPLiDAR C1M1-R2 Portable ToF Laser Scanner Kit – 12M Range |
| 107020149 | Grove – Offline Voice Recognition Module |
| 101991050 | SenseCAP S700-A 7-in-1 Compact Weather Station-Radar Rain |
| 110991806 | Weather Station Crossarm Bracket |
| 114993369 | SenseCAP Card Tracker T1000-E for Meshtastic |
| 101021133 | Grove – Color Sensor V3.0 – I2C interface – VEML6040 based |
| 101021132 | Grove – IR Line Follower Sensor V3.0 |
| 101991102 | SenseCAP S700-B 7-in-1 Compact Weather Station with Station-Solar Radiation |
| 114993591 | SenseCAP Card Tracker T1000-E for LoRaWAN |
| 101991232 | SenseCAP S600-A 6-in-1 Compact Weather Station |
| 100035718 | SLAMTEC Aurora S,Integrated Spatial Perception Module |
