Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Compact Smart Device Platform with Built-In Sensors
    When building a portable sensor device, you normally need a display, input controls, motion sensing, audio input, battery support, and wireless connectivity. This board brings these functions together around XIAO nRF52840 Plus, allowing you to focus on the interface, sensor data, and device behavior instead of assembling separate modules and wires.
  • Clear 1.14-Inch Display for Status and Simple UI
    The 1.14-inch 135 × 240 IPS TFT display provides enough space for status pages, sensor readings, icons, menus, and lightweight animations. Together with three physical buttons, it allows you to build compact interfaces that remain easy and reliable to operate without requiring a touch screen.
  • Voice, Motion, Buttons, and Grove I2C in One Board
    The onboard PDM microphone can be used for sound detection, volume monitoring, or audio capture. The 6-axis IMU detects orientation, shaking, flipping, and motion, while three user buttons provide direct physical control. A Grove I2C interface makes it easy to add environmental, distance, light, and other compatible sensors without complex wiring.
  • Built for BLE and Battery-Powered Projects
    Powered by XIAO nRF52840 Plus, this version is designed for Bluetooth Low Energy and portable projects. It can connect to phones, computers, and gateways, making it suitable for wearable notifiers, BLE remote controls, portable sensor terminals, desktop devices, and motion-aware products that do not require Wi-Fi.
SpecificationXIAO 1.47'' IPS Touch Display(nRF52840)XIAO 1.14'' IPS Display(nRF52840)XIAO 0.96'' IPS Display(nRF52840)
Product PositioningTouch & Full InteractionSensing & ExpansionUltra-Compact
Core ControllerSeeed Studio XIAO nRF52840 Plus
ProcessorNordic nRF52840, ARM® Cortex®-M4 32-bit processor with FPU, 64 MHz
Memory
256 KB RAM + 1 MB internal Flash + 2 MB onboard Flash
Wireless ConnectivityBLE 5.4
Display Type1.47" IPS TFT LCD1.14" IPS TFT LCD0.96" IPS TFT LCD
Resolution172 × 320135 × 24080 × 160
Display DriverJD9853AST7789ST7789
Display InterfaceSPI
Touch InputCapacitive TouchNoNo
6-Axis IMUYes
PDM Digital MicrophoneYes
MicroSD Card SlotYesNoNo
Grove I2C ConnectorNoYesNo
User Buttons232
Battery Connector2-pin JST 2.0 Connector for 3.7 V LiPo
Battery MonitoringBattery status detection supported; battery voltage can also be monitored for battery-level estimation.
Expansion Interfaces1x I2C Interface
1x I2S Interface
1x SWD Interface
2x User Button Interface
1x I2C Interface
1x I2S Interface
1x SWD Interface
3x User Button Interface
1x I2C Interface
1x I2S Interface
1x SWD Interface
Board Size26.4 × 51.4 × 12.6 mm26 × 48 × 10.6 mm18.8 × 43.6 × 10.6 mm
Best ForTouch UI, portable HMI, local media and data loggingPortable sensor displays, Grove devices, physical controllersSmart badges, tiny wearables, BLE status displays
Hardware Overview
  • Onboard
Application
  • Portable Sensor Display
  • Grove Environmental Monitor
  • BLE Remote Controller
  • Motion-Based Interaction Device
  • Wearable Notifier
  • Desktop Gadget and Digital Pet
Certification
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
1.14 Inch Display Powered by XIAO nRF52840 Plus×1
SKU 100069374
The XIAO 1.14'' IPS Display(nRF52840) is a ready-to-use mini smart device development board designed for sensing, physical control, and Bluetooth-connected projects. It combines a 1.14-inch IPS display, PDM digital microphone, 6-axis IMU, three user buttons, Grove I2C interface, battery connector, and the pre-soldered XIAO nRF52840 Plus on one compact board.
You can quickly build portable sensor displays, BLE controllers, motion-aware devices, wearable prototypes, desktop gadgets, and compact HMI projects without wiring multiple modules.
XIAO Dev Board
Display Size
USD$16.90
You may also add
