Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • High Contrast Display:
Provides a crisp 128×64 white OLED output with a contrast ratio typical of >10,000:1, ensuring excellent readability even in low-light environments.
  • Wide Viewing Angle:
Delivers clear visibility across >160° viewing range, thanks to the self-emissive OLED technology that avoids brightness drop at extreme angles.
  • Low Power Consumption:
Operates efficiently with typical current consumption under 20mA, making it ideal for battery-powered IoT, wearables, and portable devices.
  • SSD1306-Compatible Driver:
Fully compatible with the popular SSD1306 controller, allowing seamless integration with Arduino, Raspberry Pi, and other microcontroller platforms via I²C/SPI interfaces.
(Example: compatible with controllers similar to the one used in the Seeeduino V4.2)
  • Flexible FPC Interface:
Features a thin FPC connector design that supports easy mounting and integration into compact enclosures, enhancing mechanical flexibility for embedded applications.
  • Fast Response Time:
OLED technology enables sub-millisecond response speeds, producing smooth animations and real-time UI transitions without motion blur.
  • Long Lifetime:
High-quality OLED panel provides a typical lifetime exceeding 20,000 hours, ensuring stable performance in long-term deployments.
Parameter
Display Size
1.3 inch
Resolution
128 × 64 Dots
Display Color
White monochrome OLED
Driver IC
CH1116G
Drive Duty
1/64
Operating Voltage
3.0V – 5.0V (typical)
Operating Current
< 20 mA (typical)
View Direction
ALL
Contrast Ratio
Typically >10,000:1
Operating Temperature
-40°C to +80°C
Storage Temperature
-40°C to +85°C
Interface
8-bit68XX/80XX,3/4-wireSPI, I2C
Interface Type
Flexible FPC connector
Module size
34.5mm(W)x23.0mm(H)x1.47mm(T)
Active Area
29.42mm(W) x 14.7mm(H)
Pixel Pitch
0.23mm(W)x0.23mm(H)
Pixel Size
0.21mm(W)x0.21mm(H)
IC package type
COG
Certification
HSCODE8524929090
USHSCODE8524119000
UPC
EUHSCODE8471707000
COOCHINA
1.3inch OLED 128*64-White-FPC
x1
SKU 100015674
It's a high-contrast 1.3-inch OLED display featuring a 128×64 white panel and wide viewing angles. Designed for wearables and IoT devices, it supports SSD1306-compatible drivers and low-power operation, delivering crisp monochrome visuals for compact embedded applications.
USD$4.99
You may also add
