Product Details
Wiki & Learn
Reviews
Download PDF
This is an E-Ink display HAT for Raspberry Pi, 2.13inch, 212x104 resolution, with embedded controller, communicating via SPI interface, supports yellow, black, and white three-color display.
Due to the advantages like ultra low power consumption, wide viewing angle, clear display without electricity, it is an ideal choice for applications such as shelf label, industrial instrument, and so on.
- No backlight, keeps displaying last content for a long time even when power down
- Ultra low power consumption, basically power is only required for refreshing
- Compatible with Raspberry Pi 2B/3B/Zero/Zero W
- Preserved solder pads for SPI interface, for connecting with other controller boards like Arduino/Nucleo, etc.
- Comes with development resources and manual (examples for Raspberry Pi/Arduino/STM32)
Certification
HSCODE8517180050
USHSCODE8524119000
UPC841454120742
EUHSCODE8471707000
COOCHINA
Technical Details
Dimensions114mm x64mm x34mm
WeightG.W 18g
BatteryExclude
Specifications
Operating voltage3.3V
Interface3-wire SPI, 4-wire SPI
Outline dimension65mm × 30.2mm
Display size23.71mm × 48.55mm
Dot pitch0.229 × 0.228
Resolution212 × 104
Display coloryellow, black, white
Grey level2
Full refresh time15s
Refresh power26.4mW(typ.)
Standby power<0.017mW
Viewing angle>170°
VCC3.3V
GNDGround
NCNC
DINSPI MOSI pin
CLKSPI SCK pin
CSSPI chip selection, low active
DCData/Command selection (high for data, low for command)
RSTExternal reset, low active
BUSYBusy status output, low active
2.13inch e-Paper HAT (C)1
RPi screws pack (2pcs)1
PH2.0 20cm 8Pin1
2.13inch E-Ink display HAT for Raspberry Pi & Arduino yellow/black/white 3 color e paper
SKU 104990422
e Ink,e-ink,inky,e paper,epd,3 color,display,hat,2.13,SPI interface,Raspberry Pi, zero,arduino,STM32, low power,shelf label
USD$18.99
Discontinued
