The LED strip uses trinity-SMD LED as lighting source, it shines uniformity with high brightness. The FPC circuit board made it easily to bend with lowing voltage with resistance and having IC constant current, stable working was ensured. Designed with two solder pan, convenient for connected.
| HSCODE | 9405409000 |
| Dimensions | 0mm x0mm x0mm |
| Weight | G.W 5g |
| Battery | Exclude |
