Acrylic Case for BeagleBone Green
Rating:
100% of 100
The enclosure provides slots to access the Grove, USB ports, Ethernet, SD card, HMDI, and JTAG connectors as well as feet and vents to ensure the board gets proper cooling
$4.50
In stock
  • 10+: $4.05
  • 20+: $3.83
  • More
  • 50+: $3.60
  • Less
Interested in a customized Beaglebone Green? Check out our ODM services here!
The enclosure provides slots to access the Grove, USB ports, Ethernet, SD card, HMDI, and JTAG connectors as well as feet and vents to ensure the board gets proper cooling. All of the status LEDs on the board are visible through the case thanks to light pipes embedded in the design. This is a really slick case and once you've gotten your hands on BeagleBone Green, you'll want to snag one of these to put it in!
FEATURES
Ÿ3mm acrylic
ŸLight and easy to transport
ŸGood heat dispersion
Dimensions 145mm x100mm x13.3mm
Weight G.W 77g
Battery Exclude
Acrylic 6
M3 Net 4
M3 Screw 4
M3 Plastic Colum 4
ECCN ERA99
HSCODE 3923100090
UPC 841454114666
ROHS 1
Product Faqs
Sort by
  • Question by: admin on 2018-12-18 02:23:16
    Hi Ae, Thanks for the info! Do you know if there are any cases that support the Cape as well? I want to enclose my BBG with the cape. Thanks Nick
    Answer by: admin on 2018-12-18 02:23:16
