Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
Amazing Hand Early Bird: Only $89! Back to $99 starting March 1st, 2026. Don't miss out! Grab yours now!
  • Open-Source Design The Amazing Hand is fully open-source, with all code and mechanical designs freely available. This allows easy customization and adaptation for a wide range of robotics projects.
  • 8 Degrees of Freedom (DOF) It features eight degrees of freedom across four fingers, each with two articulated phalanxes. This enables versatile and natural hand movements.
  • Compact and Lightweigh All actuators are housed inside the hand, eliminating external cables. At only 400 g, it is lightweight and easy to integrate into various applications.
  • 3D-Printable and Cost-Effective The hand is fully 3D-printable and includes all modular components, makes it an affordable option for students, hobbyists, and researchers.
  • Ideal for Research and Education Its open-source and accessible design makes it perfect for AI experiments and robotics learning. It is also suitable for data collection and algorithm validation.
Module
Amazing Hand
Supported Controller
Raspberry Pi / NVIDIA Jetson / MCU
Operating Temperature Range
0℃~40℃
Weight
400g (without Servo)
Construction
Fully 3D printable with rigid "bones" and flexible TPU shells
Actuation
Parallel mechanism with 2x Feetech SCS0009 servos per finger
Motion
Flexion/Extension & Abduction/Adduction via differential motor movement
Feetech SCS0009 Communication Protocol
UART
Feetech SCS0009 Rated Input Voltage
5V
Feetech SCS0009 Servo Rated Torgue
1.89KG.cm
Feetech SCS0009 Rated Current
300mA
Hardware Overview
Application
Discover the Possibilities with AmazingHand! Check out our community demos to see more creative applications!
AmazingHand is designed to work with its companion open-source software, providing powerful features for teleoperation, data collection, and AI learning:
Teleoperation
AmazingHand supports multiple advanced teleoperation methods:
  • Strain Gauge Glove Control: Wear a custom glove for real-time, immersive, one-to-one control of the robotic hand.
  • Hand Posture Estimation Control: Use a standard camera to capture your hand's posture and directly map its movements to the robotic hand without any wearable devices.
Data Collection
The platform facilitates data collection for robotics research and AI training:
  • Joint Angle Recording: Log precise angle data from each servo in real-time.
  • Visual Data Capture: Synchronize and capture video feeds from a camera during operation.
  • Task Demonstration Recording: Easily record complete task demonstrations for training AI models, such as in imitation learning.
Sensor Streaming
The system can stream servo data (e.g., position, load, temperature) to a host computer for:
  • More intensive processing
  • Data visualization
  • System monitoring
Software & Community Support For detailed information on software setup and code implementation, please see our Wiki.
Certification
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOCHINA
Category
Item Name / Description
Specification / Note
Qty
Electronics
PCBA Servo Driver Board
Compatible with Seeed Studio XIAO
1
Feetech Servo
Model: SCS0009
8
Power Supply
DC Power Adapter
12V 3A (5.5*2.5mm)
1
DC Power Pigtail Cable
Female to Stripped Wire
1
Data Breakout
3-Pin Header Breakout Board
SCS-Y4-2012
8
3-Pin Cables
150mm
8
Structure
Amazing Hand Full Structural Kit
Includes fingers, palm, wrist shells & frames (Black/ABS)
1 Set
Decorative Stickers
Includes Logo & Model ID
1 Sheet
Linkage
Ball Linkage Rods
M2*L19mm Black
16
Stainless Steel Pins
D2*L10mm / D2*L16mm, etc.
1 Set
Fasteners
Assembly Screw Pack
M2, M2.5 various sizes (spares included)
1 Pack
Lock Nuts / Washers
M2-M4 sizes
1 Pack
Tools / Acc.
Phillips Screwdriver
Red Handle
1
Amazing Hand (Right Hand): The Open-Source Robotic Hand Developer Kit
SKU 100063642
Amazing Hand is a 3D-printed, open-source humanoid hand with 8 degrees of freedom and four fingers. Fully actuated internally, lightweight (400 g), and low-cost, it features flexible shells for natural movement. Perfect for research, education, and robotics, it combines dexterity, simplicity, and accessibility in one compact design.
Amazing Hand Left
USD$99.00
