seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Arduino Pro Mini 328 - 3.3V&8MHz
      SKU 102990078
      $9.95
      DISCONTINUED
      The Arduino Pro Mini is a microcontroller board based on the ATmega328p. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, an on-board resonator, a reset button, and holes for mounting pin headers. A six pin header can be connected to an USB to serial adapter to provide USB power and communication to the board.
      The Arduino Pro Mini is intended for semi-permanent installation in objects or exhibitions. The board comes without pre-mounted headers, allowing the use of various types of connectors or direct soldering of wires. The pin layout is compatible with the Arduino Mini.
      There are two version of the Pro Mini. One runs at 3.3V and 8 MHz, the other at 5V and 16 MHz.
      Dimensions
      • 0.7x1.3"(18x33mm)
      • ATmega328 running at 8MHz with external resonator (0.5% tolerance)
      • Low-voltage board needs no interfacing circuitry to popular 3.3V devices and modules (GPS, accelerometers, sensors, etc)
      • 0.8mm Thin PCB
      • USB connection off board
      • Weighs less than 2 grams!
      • Supports auto-reset
      • 3.3V regulator
      • Max 150mA output
      • Over current protected
      • DC input 3.3V up to 12V
      • On board Power and Status LEDs
      • Analog Pins: 8
      • Digital I/Os: 14
      Documents
      Technical Details
      WeightG.W 2g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 102990078
        $9.95
        DISCONTINUED
        $9.95/1pcs+
        $9.45/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
