Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Compact 10-DOF Architecture: The robot is constructed with a 3D-printed skeleton and 10 serial bus servos, providing a cost-effective yet highly capable hardware platform. Its compact size (28.3 cm height) makes it perfect for desktop operation and portable demonstrations.
  • Web-Based Visual Motion Editor: The control software is browser-based, eliminating the need for local installation. It enables real-time servo angle adjustment, “Teaching Mode” for physical motion recording (drag-and-record), and exports motion data in standard JSON format for parsing by external microcontrollers.
  • Modular Control System (RUC-01 + XIAO): The system utilizes the RUC-01 adapter board as a power and communication hub (5V/3.3V power management, 4-channel servo bus, USB-C). It pairs with the Seeed Studio XIAO ESP32S3 and a Grove expansion shield, facilitating easy connection to sensors and Bluetooth remote control implementation.
  • Bluetooth Teaching & Control: Optimized for the XIAO ESP32S3, the robot supports Bluetooth remote control features including real-time motion execution, reset, damping mode activation, and speed adjustment during teaching playback.
Details
Dimensions
15.8 × 11.0 × 28.3 cm
Degrees of Freedom
10 DOF
Actuator
Fashionstar RA8-U25H-M Serial Bus Servo (x10)
Servo Upgrade Support
Compatible with RP8-U45H-M / RX8-U40H-M
Controller Architecture
Seeed Studio XIAO ESP32-S3 (Default Demo) / Compatible with nRF52840
Interface Board
RUC-01 (Power Management, UART, Servo Bus, Type-C)
Expansion Interface
Grove Connector (via XIAO Shield)
Communication Protocol
Asynchronous Serial (UART)
Power Input
High-rate Lithium Battery (Not included)
Supported Platforms (Editor)
Windows / Linux / macOS (Web Browser based)
External Control Support
Raspberry Pi, STM32, Arduino, ESP32 (via UART)
Material
FDM 3D Printed Structure (Data Open Source)
Hardware Overview
Application
  • Motion Algorithm Verification
A simplified 10-DOF structure allows beginners to focus on fundamental gait algorithms and balance control without the complexity of a full-sized humanoid.
  • Embedded System Education
Using the Seeed Studio XIAO ESP32S3, students can learn Bluetooth Low Energy (BLE) communication, sensor integration using the Grove ecosystem, and bus servo protocols.
  • Remote Control & Interaction
The integrated Bluetooth capabilities allow for the development of interactive remote control applications, including damping mode teaching (physically posing the robot) and remote motion triggering.
  • Desktop Robotics Development
The compact form factor makes it an excellent desktop companion for developers testing logic for larger robots or IoT interactions via ESP32/nRF52840.
Certification
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOCHINA
  • Fashionstar RA8-U25H-M Serial Bus Servo × 10
  • RUC-01 Control Adapter Board × 1
  • Seeed Studio XIAO ESP32S3 Microcontroller × 1
  • XIAO Expansion Shield × 1
  • 3D Printed Structural Components (10-DOF Set) × 1
  • USB Type-C Cable × 1
  • Assembly Hardware Kit (Screws, Nuts) × 1
Fashionstar Atom S 10-DOF Open Source Robot Kit
SKU 100064698
The Fashionstar Atom S is a fully open-source, 10-degree-of-freedom (DOF) humanoid robot platform designed for robotics education and algorithm development. Driven by 10 Fashionstar RA8-U25H-M serial bus servos and equipped with the Seeed Studio XIAO ESP32S3 controller, it natively supports Wi-Fi and BLE wireless development while remaining compatible with the entire Seeed Studio XIAO series. The system features a web-based visual motion editor for real-time debugging and supports cross-platform integration via UART, compatible with Raspberry Pi, ESP32, and STM32 environments, making it an ideal platform for learning servo control, gait planning, and embedded systems.
X 17-DOF Open Source Robot Kit
USD$269.00
