Built with an imported STM32 microcontroller, the UTC-T01 ensures stable communication across a wide baud rate range of 5kbps to 1Mbps. It fully supports the standard CAN 2.0A protocol, designed to withstand rigorous development environments.
PCAN Mode (Default): Functions as a standard PCAN-USB device, natively compatible with professional tools like PCAN-View, PCAN-Explorer, and TS-Master. It also supports flashing open-source firmware like SLCAN and candlelight.
Transparent Mode: Designed for easy integration. It maps as a driver-free virtual serial port, allowing you to interact with the CAN bus using standard serial commands, perfect for secondary development.
Break free from OS limitations. The device supports Windows (XP/7/8/10/11), Linux (Ubuntu, Raspberry Pi OS), and Android. Whether you are on a desktop workstation or an edge device like the Jetson Nano, your workflow remains uninterrupted.
A physical DIP switch allows for instant configuration without jumpers. Easily toggle the 120Ω terminal resistor, switch between 0R, or enter BOOT mode for firmware upgrades. Three distinct LEDs (PWR, TXD, RXD) provide real-time visual feedback on bus activity.
The UTC-T01 supports firmware online upgrades and provides source code and tools for secondary development. Advanced features include multi-frame sending, cyclic sending, and ID filtering to streamline your debugging process.
Overview of peripheral interfaces including LEDs and Terminal pins.
| HSCODE | 8471800000 |
| USHSCODE | 8471801000 |
| UPC | |
| EUHSCODE | 8471707000 |
| COO | CHINA |
1x UTC-T01 USB-to-CAN Adapter
The UTC-T01 is more than just an adapter; it is a compact, industrial-grade bridge between your workstation and the physical CAN bus. Powered by a robust STM32 chipset, it delivers stable communication ranging from 5kbps to 1Mbps. With a versatile dual-mode design (PCAN firmware and Serial Transparent Transmission) and cross-platform support for Windows, Linux, and Android, it enables seamless data analysis and secondary development for embedded engineers and FPGA developers.
