seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Crazyflie 2.0 - BigQuad Deck
      SKU 102990227
      $7.00
      8 Available
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      With the BigQuad deck you can transform your Crazyflie 2.0 to a bigger quad by connecting external ESCs (Electronic Speed Controller) to the breakout connectors on the deck. The autodetection of the deck makes this transformation possible to do in seconds. The deck contains breakout header connectors for additional accessories such as external receiver (CPPM input) and GPS. It also has the possibility to monitor battery voltage and current.
      This product is intended to be used together with the Crazyflie 2.0 quadcopter and uses its expansion board system. Please have a look at the buyers guide for more info about the Crazyflie 2.0 ecosystem. For more information about how to use the expansion decks check out the getting started with expansion deckspage.
      This product is in early access stage. It means that while the hardware is working and tested, the software is still pretty much work in progress. For more information see the early access description page.
      FEATURES
      • 4 x ESC connectors
      • 0.1"header mounting holes for additional connectivity:
      • CPPM input (3 pin)
      • GPS input (4 pin)
      • I2C expansion  (4 pin)
      • Battery and current monitoring input (3 pin)
      • Buzzer output (2 pin)
      • Connect one or two additional decks
      • Automatic detection of expansion deck
      Technical Details
      Dimensions36mm x 40mm x 5mm
      WeightG.W 6g
      BatteryExclude
      Power Crazyflie 2.04.5V - 5.5V from ESC.
      BiqQuad deck inputs5V tolerant
      Battery voltage monitoring divider scaled for inputup to 23V
      Current monitoring input0V - 3V
      BiqQuad deck and Crazyflie 2.0 current consumption1. ~120mA without any additional decks. 2. Up to 500mA if Crazyflie 2.0 battery is connected and charging.
      1-wire memory for automatic expansion deck detection
      M3 mounting holes placed 30.5mm square.
      Designed for mounting above or under the Crazyflie 2.0
      BigQuad deck1
      M2x4 nylon screw4
      M2x6 hex spacer2
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 102990227
        $7.00
        8 Available
        Maximum Qty: 5
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
