Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
This brick includes a PIR motion sensor module,Max sentry distance is 7 meters. If anyone moved in that range, Alarm pin will go high. The signal duration can be adjusted from 0.3s-18s by the yellow potienmeter.
Documents
Documents
Certification
HSCODE
Technical Details
Dimensions0mm x0mm x0mm
WeightG.W 9.5g
BatteryLithium Cells / Batteries loose (bulk) UN3480-PI965
Electronic brick - PIR motion sensor(digital)1
SKU 101990036
USD$11.50
Discontinued
You may also add
