Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Integrated Design Provides Integrated design of brushless motor, reducer, magnetic absolute encoder and controller
  • 12-bit absolute encoder Includes 12-bit magnetic absolute encoder, supporting arbitrary angle setting as the zero-position and multi-turn angle control
  • Angle memory Ensures position data is retained after power-off.
  • Smooth motion curve Trapezoidal acceleration and deceleration control profile generates a smoothed motion curve
  • Comprehensive protection features Provides comprehensive protection functions including thermal shutdown, voltage protection, stall detection, and current/power limitation
Product
Fashionstar RX8-U50H-M
Voltage
9V ~ 12.6V
Operating Temperature
-10℃~60℃
Mechanical Dimension
40mm x 40mm x 20mm
Communication Interface
UART/TTL Half-Duplex
Baud rate
9,600bps~1Mbps
Resolution
0.088°
Operating Mode
Single-turn Angle Control Mode
Multi-turn Angle Control Mode
Damping Mode
Max Stall Torque
4.9N·m (50kg-cm)
Max Continuous Torque
2.26N·m (23kg-cm)
Rated Speed
52rpm(0.192sec@60°)
Hardware Overview
Application
Robotic Arm
Documents
Certification
HSCODE8501109990
USHSCODE8501106080
UPC
EUHSCODE8501109390
COO
RX8-U50H-M Servo
x1
Horn
x2
PM M3*6mm Screw
x1
PM M2*4.5mm Screw
x26
200mm 3-pin Cable (PH2.0×2)
x1
Fashionstar RX8-U50H-M servo
SKU 114090077
Fashionstar RX8-U50H-M Servo is a 12V 50kg dual-shaft serial bus servo with bracket that integrates brushless motor, reducer, magnetic absolute encoder and controller. With a 387:1 reduction ratio, the servo's stall torque comes at 50 kg. cm and the rated torque at 23kg. cm. Designed for versatility, it is suited for use in industrial automation, robotics, and low-torque drive applications. It comes with ample code examples that can help accelerate deployment and integration.
USD$112.00
