the AI Hardware Partner
Toggle Nav
Loading...
Grove - GPS Module
Rating:
100 % of 100
The Grove - GPS module is a cost-efficient and field-programmable gadget armed with a SIM28 module and serial communication configuration, providing a precise, sensitive, low power GPS module for position recognition anywhere in the world.
$19.99
Out of stock
  • 10+: $13.99
Tip
We also released new Grove - GPS (Air530), which is a high-performance, highly integrated multi-mode satellite positioning and navigation module, supporting plenty of location systems, such as GPS/Beidou/Galileo and etc.
  • Supports NMEA and U-Blox 6 protocols.
  • Low power consumption
  • Baud rates configurable
  • Grove UART interface
  • Both compatible with Arduino and Raspberry Pi.
If you put your Raspberry Pi or Arduino in the wild, can you track its location? If you had this GPS module, you can make it!
The Grove - GPS module is a cost-efficient and field-programmable gadget armed with a SIM28 module and serial communication configuration. Similar to other Grove series sensors, it plugs directly into the Grove UART interface development board and provides a precise, sensitive, low power GPS module for position recognition anywhere in the world. It features 22 tracking / 66 acquisition channels GPS receiver. The sensitivity of tracking and acquisition both reach up to -160dBm, making it a great choice for personal navigation projects and location services, as well as An outstanding one among products of the same price class.
How do GPS modules work?
Satellite Technology. GPS modules contain tiny processors and antennas that directly receive data sent by satellites through dedicated RF frequencies. From there, it’ll receive timestamp from each visible satellites, along with other pieces of data. If the module’s antenna can spot 4 or more satellites, it’s able to accurately calculate its position and time.
This GPS module can be used to locate your Raspberry Pi and Arduino. To realize its tracking function, some basic elements will be needed, here is a table to introduce them.
Grove – GPS Module vs Grove – GPS (Air530)
Specs
Grove – GPS Module
Size
40mm x 20mm x 13mm
40mm x 20mm x 13mm
Update Rate
1Hz, max 10Hz
Baud Rate
9,600 – 115,200
9600 –921600
Navigation Sensitivity
-160dBm
–166dBm
Power Requirements
3.3/5V
3.3/5V
Number of Channels
22 tracking, 66 channels
Time to first start
Cold start: 13s
Warm start: 1-2s
Hot start: <1s
Cold start: 30 seconds
Warm Start: 4 seconds
Antennas
Antenna included
Antenna included
Accuracy
2.5m GPS Horizontal Position Accuracy
2.5m Horizontal positioning accuracy
Use Grove - GPS module with different expansion boards to extend more possibilities.
Product NameApplication
Grove Base Hat for Raspberry Pi Expansion Board for Raspberry Pi 2/3B/3B+/4/Zero
Grove Pi+ Expansion Board for Raspberry Pi model B/B+/A+/2/3
Base Shield V2 Expansion Board for Arduino Uno and Seeeduino
Grove Cables Connect the sensor with the expansion board
Note
The accessories above do not include Raspberry Pi, Arduino or Seeeduino. If you need any kind, please view the following links.
Raspberry Pi: Raspberry Pi 4 / Raspberry Pi Zero
Arduino: Arduino Uno  / Arduino Leonardo  / Arduino Due
Seeeduino: Seeeduino Maga / Seeeduino V4.2  / Seeeduino Lite
Applications
  • GPS tracker
  • GPS navigation
  • Distance measurement
Specificaition
  • Input Voltage: 3.3/5V
  • BaudRate: 9600 - 115200
  • Default BaudRate: 9600
Dimensions 40mm x20mm x13mm
Weight G.W 17g
Battery Exclude
Grove - GPS 1
Grove - Cable 1
HSCODE 8529101000
USHSCODE 8525501000
UPC 841454108290
EUHSCODE 8517600000
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    This user did not leave any comments.
    By
  2. Product Quality
    100%
    By
  3. Product Quality
    100%
    By
  4. Product Quality
    100%
  5. Product Quality
    100%
    By
Items 1 to 5 of 7 total
Page
Show per page
