Grove - EL Driver is designed for driving EL Wires.It integrates a very small inverter to drive the EL Wire, so you can easily light up the EL Wire with just one single Grove cable.
Features:
Grove compatible interface
3.3V/5V Compatible
Integrated Inverter Transformer
Specification:
Input Current: 300mA Max (According to the load)
Input Voltage 3~5Vdc
Output Voltage:70~110Vpp
Output frequency: 8~20kHz
Supported max EL Capacitance: 15nF
| Dimensions | 130mm x90mm x10.5mm |
| Weight | G.W 14g |
| Battery | Exclude |
| Grove - EL Driver | 1 |
