Grove Indoor Environment Kit for Intel® Edison
SKU 110060064
  • Create indoor applications easily
  • Rich grove modules and cables
  • Cool demo codes
  • No coding experience required
    Free Express Shipping on Orders over $200!
    $79.00
    5 Available
    Qty:
    This field is required
    ADD TO CART
    $79.00/1pcs+
    $71.10/10pcs+
    $67.15/20pcs+
    $63.20/50pcs+
    Create Cool Indoor Environment Applications without Programming Experience!
    A functional kit to help you explore and interact with your indoor environment. A bundle of various sensors expands your imagination in rapid prototyping based on an Intel Edison development board.
    WHAT IS IT?
    Grove Indoor Environment Kit for Intel® Edison makes it easy to create complete indoor environment applications with Intel Edison and Arduino Breakout Board. With the Base shield V2, developers can plug up to 11 different Grove sensors and actuators quickly. We provide cool demo codes which are constantly updated, so as to make it simple to operate even without any programming experience.
    WHAT'S INSIDE?Base Shield V2 x 1Grove - LCD RGB Backlight x 1Grove – Temperature & Humidity Sensor x 1Grove - Relay x 1Grove - Moisture Sensor x 1Grove - Servo x 1Grove - Light Sensor x 1Grove - Buzzer x 1Grove - UV Sensor x 19V to Barrel Jack Adapter x 1Grove - PIR Motion Sensor x 1
    26AWG Grove Cables x 2Grove - Encoder x 1
    USB Cable x 1Grove - Button x 1
    User Guide x 1
    PROJECTS
    Project 1: Light Control Switch
    How does it work?
    When the illumination<300, the servo will drive the switch. Just connect to PC, open the Serial Monitor and type the command “set light<300, servo=90”, then click “Send” button.
    Part list:
    Grove - Light Sensor, Grove – Servo, 26AWG Grove Cables
    Project 2: Infrared LampInfrared Lamp
    How does it work?
    Connect to PC, open the Serial Monitor and type the command “set pir=1, relay=1”, then click “Send” button. Then turn on the power, the PIR Motion Sensor will lighten the lamp when it feels body motions or people passing by.
    Part list:
    Grove - PIR Motion Sensor, Grove – Relay, 26AWG Grove Cable
    Project 3: UV AlarmUV Alarm
    How does it work?
    The buzzer will alarm when UV goes beyond 55. Connect to your PC, open the Serial Monitor and type the command “set uv>55, buzzer=1”, then click “Send” button.
    Part list:
    Grove - UV Sensor, Grove – Buzzer, 26AWG Grove Cable
    DOCUMENTS
    Please visit our Wiki page for more info about this product. It will be much appreciated if you can help improve the documents, add more demo code or tutorials.
    For technical support, please post your questions to our Forum.
    See More
    $50 Featured List
    $100 Featured List
    $200 Featured List
    Don’t miss out!
    Reviews
    See More
    Questions and Answers
    SUBMIT
    See More
    View History
    Documents
    Best-sellers
    SUBMIT
    Invalid email address.
