Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
The Grove - Laser PM2.5 Sensor (HM3301) is a new generation of laser dust detection sensor,  which is used for continuous and real-time detection of dust in the air. Its stable output, low noise, and ultra-low power consumption make it suitable for air conditioners, intelligent air cleaners, and other air quality-related IoT projects.
  • Real-time detection: Real-time & continuous detection of dust concentration in the air
  • High sensitivity: High sensitivity on dust particles of 0.3 μm or greater
  • Stable data reading: Based on laser light scattering technology, readings are accurate, stable, and consistent
  • Low-power: Low noise and Ultra-low power consumption
  • Grove compatible interface: The product ensures "Plug and Play" and could be versatile for various applications of Grove
Different from the traditional pumping dust detection sensor, the HM-3301 innovatively uses fan blades to drive air, and the air flowing through the detection chamber is used as a test sample to perform a real-time and continuous test on the dust of different particle sizes in the air.
This module is a perfect choice for dust detectors, intelligent air purifiers, intelligent air conditioners, intelligent ventilation fans, air quality testing, haze meters, environmental monitoring, and comparable products and applications.
For detailed technical information, tutorials and related projects about this product, please refer to our wiki: Grove - Laser PM2.5 Sensor (HM3301)
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Applications
  • Air purifier, air conditioner
  • Air quality testing equipment
  • Industrial PM value analysis
  • Dust and smoke detection and analysis
  • Real-time PM2.5, PM10, TSP detector
  • Multichannel particle counter
  • Environmental testing equipment
Upgrade to Industrial Solutions
Specifications
Operating Voltage3.3V / 5V
Operating temperature-10~60℃
Operating humidity10%~90%RH (non-condensing)
Particle size3 channels-- 2.5µm, 5µm, 10µm
Range
(PM2.5 standard value)
1~500µg/ m3 (Effective range)
1000 µg/ m3 (Maximum range)
ResolutionConcentration: 1µg/ m3
Counting concentration: 1s/0.1L
Stability time30 seconds after power-on
InterfaceI2C
I2C address0x40
Pin Out
Grove - Laser PM2.5 Sensor (HM3301)1
Grove Cable1
Certification
HSCODE9031809090
USHSCODE9031808085
UPC841454121794
EUHSCODE9013101000
COOCHINA
Grove - Laser PM2.5 Dust Sensor - Arduino Compatible - HM3301
SKU 101020613
The Grove - Laser PM2.5 Sensor (HM3301) is a new generation of laser dust detection sensor,  which is used for continuous and real-time detection of dust in the air. With its stable output, low noise, and ultra-low power consumption, it is suitable for air conditioners, intelligent air purifiers, and other air quality-related IoT projects.
Dust Sensor
USD$29.61
$32.90
Save $3.29(10%)
You may also add
