the AI Hardware Partner
Toggle Nav
Loading...
Grove Starter Kit Plus - IoT Edition
Grove Starter Kit Plus, edison,Starter Kit Plus, Grove Starter
$29.90
Out of stock
No soldering, no jumper wires, no jitters. Simple, easy, and fast. This is how this kit gonna make you feel when you use it to make your IoT devices - a totally enjoyable making process.
The Grove Base Shield in the kit can works on a lot of Arduino compatible development boards including the Intel Edison for Arduino, LinkIt One, and Genuino 101 etc.
Beyond the Grove Shield is a bunch of Grove sensors and actuators with build-in Grove interfaces, makes your prototyping faster and easier. Simply plug in the modules and you are ready to create.
  • Various sensors and actuators for rapid prototyping
  • Plug-and-play modules
  • Works on lots of Arduino Compatible Boards
Dimensions 0mm x0mm x0mm
Weight G.W 886g
Battery Exclude
Grove- Button 1
Grove - Sound Sensor 1
Grove - 3-Axis Digital Accelerometer(±1.5g) 1
Grove - Touch Sensor 1
Grove - Light Sensor 1
Grove - Temperature Sensor 1
Grove - Rotary Angle Sensor(P) 1
Grove - Pieze Vibration Sensor 1
Grove - LCD RGB Backlight 1
Grove - Buzzer 1
Grove - Green LED 1
Grove - Blue LED 1
Grove - Red LED 1
Gear Stepper Motor with Driver 1
Grove Base Shield V2 1
12V 2A American Standard AC/DC Power Adaptor 1
British Standard Plug Converter 1
European Standard Plug Converter 1
Australian Standard Plug Converter 1
Micro USB Cable 1
HSCODE 9023009000
COO CHINA
RoHS 1
