seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - Temperature&Humidity Sensor (High-Accuracy & Mini)
      SKU 101020074
      $11.50
      34 Available
      $11.50/1pcs+
      $10.35/10pcs+
      $9.78/20pcs+
      $9.20/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      This is a multifunctional sensor that gives you temperature and relative humidity information at the same time. It utilizes a TH02 sensor that can meet measurement needs of general purposes. It provides reliable readings when environment humidity condition inbetween 0-80% RH, and temperature condition inbetween 0-70°C, covering needs in most home and daily applications that don't contain extreme conditions.
      • Wide operating voltage range:(3.3V ~ 5V)
      • Low Power Consumption:350 µA during RH conversion
      • 0 to 100% RH operating range
      • Measuring Range:
      • Humidity: 0% - 80% RH Temperature: 0 ~ 70 °C
      • Accuracy:
      • Humidity: ±4.5% RH
      • Temperature: ±0.5°C
      • ŸI2C host interface
      • Excellent long term stability
      Technical Details
      Dimensions90mm x 60mm x 10mm
      WeightG.W 9g
      BatteryExclude
      Grove - Temperature&Humidity Sensor (High-Accuracy &Mini) v1.01
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hi, does this sensor work with grove pi on raspberry pi 3? Thank you!
      on Apr 14,2018
      Replyupvote ()
      Hi Simon~ Yes, this sensor can work with Grove pi on Raspberry pi 3. And you can find the dome code here.====================================================================https://github.com/DexterInd/GrovePi/tree/master/Software/Python/grove_i2c_temp_hum_sensor_mini
      on Apr 16,2018 10:49 AM
      Replyupvote ()
      Reply
      0
      Hello, does this work with a Beaglebone Green Wireless? Thanks!
      on Mar 11,2018
      Replyupvote ()
      Hi three~ Unfortunately, this one can not work with Beaglebone Green. Regards
      on Mar 12,2018 10:21 AM
      Replyupvote ()
      Reply
      0
      Hello, would you know if this works on Intel Galileo/Edison? Thanks!
      on Oct 19,2016
      Replyupvote ()
      Yes, thanks.
      on Feb 09,2017 14:42 PM
      Replyupvote ()
      Reply
        View History
        SKU 101020074
        $11.50
        34 Available
        Maximum Qty: 5
        $11.50/1pcs+
        $10.35/10pcs+
        $9.78/20pcs+
        $9.20/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
