the AI Hardware Partner
Toggle Nav
Loading...
GrovePi+
GrovePi+ is add-on board with 15 Grove 4-pin interfaces that brings Grove sensors to the Raspberry Pi.
$34.50
In stock
  • 10+: $31.00
  • Compatible with many development boards: Including Raspberry Pi model B/B+/A+/2/3/4
  • Faster SPI and higher reliability UART connections
  • Easier to assemble camera cables and LCD cables
  • Simplified procedures of firmware update
GrovePi+ is add-on board with 15 Grove 4-pin interfaces that brings Grove sensors to the Raspberry Pi. It is the newest version compatible with Raspberry Pi model B/B+/A+/2/3/4 perfectly. There are three mounting holes can perfect match all version of Raspberry Pi. Camera cable outlet hole. It also improves the voltage level converting sub circuits.
GrovePi+ is an easy-to-use and modular system for hardware hacking with the Raspberry Pi, no need for soldering or breadboards: plug in your Grove sensors and start programming directly. Grove is an easy to use collection of more than 100 inexpensive plug-and-play modules that sense and control the physical world. By connecting Grove Sensors to Raspberry Pi, it empowers your Pi in the physical world. With hundreds of sensors to choose from Grove families, the possibilities for interaction are endless.
Note
Raspberry Pi board is not included.
Grove Base Hat for Raspberry Pi Vs. GrovePi+
Parameter
GrovePi+
Working Voltage
3.3V
5V
MCU
STM32F030F4P6
ATMEGA328P
Grove Ports
6 Digital(3.3V) 4 Analog(3.3V) 3 I2C(3.3V) 1 PWM(3.3V) 1 RPISER(UART) connect to Raspberry Pi(3.3V) 1 SWD
7 Digital(5V) 3 Analog(5V) 3 I2C(5V) 1 SERIAL: Connect to ATMEGA328P D0/1(5V) 1 RPISER: Connect to Raspberry Pi(3.3V) 1 ISP
Grove-Digital
Connect to Raspberry Pi directly
Connect to ATMEGA328P digital pins and transfer to I2C signal, then through level converter to Raspberry Pi
Grove-Analog
Connect to STM32F030F4P6(12bit ADC) and then transfer to I2C signal,route to Raspberry Pi directly
Connect to ATMEGA328P analog pins(10bit ADC) and then transfer to I2C signal, then through level converter to Raspberry Pi
Grove-I2C
Connect through level converter to Raspberry Pi
Grove-PWM
NA
RPISER
SERIAL
NA
Connect to ATMEGA328P digital pins D0/D1 and transfer to I2C signal, then through level converter to Raspberry Pi
SWD
Burn firmware to STM32F030F4P6
NA
ISP
NA
Burn firmware to ATMEGA328P
Raspberry Pi Connector Pins
40
26
Specifications
Dimensions
88mm x58mm x23mm
Weight
G.W 51g
Battery
Exclude
Grove header Vcc output Voltage
5Vdc
Digital ports
7
Aanaloge Ports
3
I2C ports
3
Serial port connect to GrovePi
1
Serial port connect to Raspberry Pi
1
Hardware Overview
Grove Pi+
1
HSCODE 8543909000
USHSCODE 8543708800
UPC 841454100034
EUHSCODE 8543709099
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    Excellent product and documentation easy to use
    By
  2. Product Quality
    100%
    Documentation
    100%
    from order view
    This user did not leave any comments.
    By
  3. Product Quality
    100%
    Documentation
    100%
    from order view
    I have had a PI 4 for a while but recently wanted to use my Groove components. This is a great way to use my existing Groove parts with my PI 4.
    By
  4. Product Quality
    80%
    By
  5. Product Quality
    100%
    By
Items 1 to 5 of 9 total
Page
Show per page
