Product Details
Wiki & Learn
Reviews
Download PDF
I2C_LCD is an easy-to-use display module, It can make display easier. Using it can reduce the difficulty of make, so that makers can focus on the core of the work.
We developed the Arduino library for I2C_LCD, user just need a few lines of the code can achieve complex graphics and text display features.
More than that, we also develop the dedicated picture data convert software (bitmap converter),now is available to support PC platform of windows, Linux, Mac OS. Through the bitmap convert software you can put your favorite picture displayed on I2C_LCD, without the need for complex programming.
  • Only 2 Arduino pins are occupied (Use I2C interface).
  • Arduino library supported, use a line of code to complete the display.
  • 168 ASCII characters can be displayed.
  • 128X64 dual color picture can be displayed.
  • Provide dedicated picture data convert software (Bitmap Converter) .
  • Adjustable backlight brightness and contrast.
  • Support modify device address, can support 127 modules work in parallel.
  • Convenient Grove interface.
  • China style unique appearance.
Dimension
  • 1x I2C_LCD
  • 1x Grove - Universal 4 Pin Buckled 12cm Cable
If you want to use I2C_LCD with traditional Arduino boards ( The boards with female connectors, like Arduino Uno and so on ), please refer to another version of I2C_LCD (With 4 pin female jumper to Grove 4 pin conversion cable).
Documentation
Technical support: [email protected]
Certification
HSCODE8531200000
USHSCODE8531200020
UPC841454118473
EUHSCODE8531202090
COOCHINA
Technical Details
Dimensions67mm x50mm x9mm
WeightG.W 20g
BatteryExclude
I2C_LCD PCBA1
Grove cable1
I2C_LCD (With universal Grove cable)
SKU 114990502
lcd, display, arduino, screen, i2c, oled
USD$20.00
Discontinued
