Intel® Edison Breakout Kit
SKU 102100001
  • Dual core, 500MHz Intel® Atom™ CPU at and 00 MHz 32-bit Intel® Quark™ microcontroller
  • 40 GPIOs, 1GB LPDDR3, 4 GB EMMC
  • Dual-band WiFi and BTLE
    $72.50
    28 Available
    Qty:
    This field is required
    ADD TO CART
    $72.50/1pcs+
    $69.50/10pcs+
    This Kit includes a tiny Edison fits nicely onto a breakout board - sort of like a tiny IoT sparrow into a very small nest, so you can expose the native 1.8 V I/O of the Edison.
    And it is for non-Arduino users. This breakout board has a minimalistic set of features and is slightly larger than the Edison module.
    Dimensions: 61mm x 29mm x 12mm
    • Uses a 22nm Intel® SoC that includes a dual core, dual threaded Intel® Atom™ CPU at 500MHz and a 32-bit Intel® Quark™ microcontroller at 100 MHz.  It supports 40 GPIOs and includes 1GB LPDDR3, 4 GB EMMC, and dual-band WiFi and BTLE on a module slightly larger than a postage stamp.
    • The Intel Edison module will initially support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future.
    • It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service.
    • The breakout board has exposes native 1.8V I/O of edison module. And 0.1'' grid I/O array of through-hole solder points. USB OTG with USB Micro Type-AB connector, USB OTG power switch. Battery Charge, USB to device UART bridge with USB Micro Type-B connector,  DC power supply jack (7V – 15V DC input).
    Physica
    Form factor            Board with 70-pin connector
    Dimensions            61mm x 29mm x 12mm
    Operating temperature            0 to 40 degC
    Connector            Hirose DF40 Series
    (1.5mm, 2.0mm, or  3.0mm stack height)
    Memory
    Max Memory size            4GB
    Memory type            DDR3, Nand Flash
    Physical add. Ext.            32-bit
    # of  DIMMs            0
    ECC Memory supported:             NO
    External Interfaces
    Total of 40 GPIOs which can be configured as:
    SD Card            1 Interface
    UART            2 Controllers
    I2C            2 Controllers
    SPI            1 Controller with 2 chip selects
    I2S            1 Controller
    GPIO            Additional 12 (with 4 capable of PWM)
    USB 2.0            1 OTG Controller
    Clock Output            32 KHz, 19.2 MHz
    Major Edison Components
    SoC            22nm Intel SoC includes: a dual core, dual threaded Intel Atom CPU at 500MHz, and a 32-bit Intel Quark microcontroller at 100 MHz
    RAM            1 GB LPDDR3 POP memory
    Flash Storage            4 GB eMMC
    WiFi            Broadcom 43340 802.11 a/b/g/n
    Dual-band (2.4 and 5 GHz)
    On board antenna or external antenna SKU configurations
    Bluetooth            BT 4.0
    Power
    Input            3.3V – 4.5V
    Output            100ma @3.3V and 100ma @ 1.8V
    Power            Standby (No radios): 13mW
    Standby (BT 4.0): 21.5mW
    Standby (WiFi): 35 mW
    Firmware + Software
    CPU OS            Yocto Linux v1.6
    Development Environments            Arduino IDE
    Eclipse supporting: C, C++ & Python
    Intel XDK supporting: Node.JS & HTML5
    MCU OS            RTOS
    Development Environments            MCU SDK and IDE
    Documents
    Related Products
    See More
    $50 Featured List
    $100 Featured List
    $200 Featured List
    Don’t miss out!
    Questions and Answers
    SUBMIT
    See More
    Recommended Products
    View History
    Best-sellers
    SUBMIT
    Invalid email address.
