Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • PCIe Gen3 8Gb/s Interface, up to 4 Lanes
  • Compliant with NVMe Express Revision 1.4
  • Support Host Memory Buffer
  • TLC NAND flash memory chips
  • Support TRIM & S.M.A.R.T, and AES-255
  • Graphite-coated copper foil and aluminum foil, enhancing heat dissipation performance
Physical
Specifications
SSD
Capacity
256GB
Interface
PCIe Gen3 x4; NVME 1.4
Form Factor
M.2 Type 2280-S2-M
Operating Temperature
0°C to 70°C
Storage Temperature
-40°C to 85°C
System Image
JetPack 6.2;Base Image
SDK Size
14.2GB
Operating Voltage
3.3V±0.2V DC
Weight
9g
Dimensions
80mm(L) x 22mm(W) x 2.5mm(H)
Performance
Specifications
SSD
Capacity
256GB
Max Sequential Read Speed
3000MB/s
Max Sequential Write Speed
900MB/s
Endurance (TBW)
200TBW
Application
  • Fully Compatible with NVIDIA® Jetson Orin™ Nano Super Developer Kit
Certification
HSCODE8471701100
USHSCODE8523510000
UPC
EUHSCODE8517180000
COOCHINA
256G NVME SSDx1
Screwx1
Phillips Screwdriverx1
256GB NVMe M.2 SSD (JetPack 6.2 Base Image) - Fully Compatible with Jetson Orin Nano Super Dev Kit
SKU 100014960
The 256GB NVMe SSD pre-installed with the JetPack 6.2 base image for the NVIDIA® Jetson Orin™ Nano Super Developer Kit. It features built-in CUDA and TensorRT to provide an out-of-the-box bootable solution, eliminating tedious environment configuration and accelerating the deployment of edge AI projects.
256G SSD with JetPack 6.2 Full Image & Source Code
USD$83.00
