This is a low cost yet versatile function generator capable of producing many different waveforms. As an easy-to-use tool operation of FG085 is very simple and straightforward. It is an ideal test/experiment tool for electronics hobbyists and students.
Frequency range: 0 - 200KHz (Sine)
Frequency resolution: 1Hz
Period resolution: 1ms
Amplitude range: 0 - 10V peak-to-peak
Offset range: -5V - +5V
Memory depth: 256 bytes
Sample rate: 2.5Msps
Output impedance: 50 ohm
Power supply voltage: DC 15V
Current consumption: < 150mA (without loading)
Dimension: 155 X 55 X 30 mm
Net weight: 100 gram
Features implemented as of current firmware
Generating continuous Sine, Square, Triangle, Ramp (up and down), and Staircase (up and down) signals
Generating servo test/control signals with user defined pulse width, amplitude, and cycle [ NEW ]
Setting of frequency (or period), amplitude, and offset is done with digits - quick and straightforward
Frequency (period), amplitude, and offset can be incrementally adjusted up and down with rotary encoder
Settings are memorized after power down.
Can be used as an adjustable DC voltage source by setting amplitude to 0
Features to be implemented (hardware support already in place)
Generating arbitrary signals
Generating special test signals NTSC/PAL video synchronous signal, and more
