Mini Soldering Iron - Europe Standard (Shape-BC2)
SKU 110990481
74.90
OUT OF STOCK
This item is not available at the moment
Get notified when it's back in stock
Mini Soldering Iron, is a small, lightweight, quick heating up soldering pencil for great soldering application. Temperature can be controlled accurate, stable and easy adjusted from 100 to 400 Celsius with STM32. Benefit from dual temperature and accelerated sensors, the solder can be in sleep mode and overheating warning automatically. Soldering iron tips can be replaceable for 4 types and can be programmed software.
  • Portable and lightweight. More convenience for soldering.
  • Easy temperature control
  • Sleep mode, which good for safety use and extend lift of soldering tips.
  • Alert mode, screen appears “warning” when temperature is higher than 400℃.
  • Solder iron tips can be changeable.
  • Software can be rewrote and programmed.
  • The power adapter accepts 100V-240V voltage input.
Specifications
Screen
OLED
USB Port
Micro USB
Power Port
DC5525
Operating Part Dimensions
Length: 96mm, Diameter: 16.5mm
Heating Part Dimensions
Length: 33mm, Diameter: 5.5mm
Weight
33g (power adaptor not included)
Operation Specifications
Power
65W
Adjustable Temperature Range
100℃ - 400℃
Temperature Stability
±2%
  • Mini Soldering Iron Operating Part x 1
  • Solder iron tip type-BC2 x 1
  • DC5525 power adaptor (Europe Standard) x 1
  • Earth clamps x 1
For technical support and suggestions, please visit our forum.
Technical Details
Dimensions154mm x 87mm x 60mm
WeightG.W 374g
BatteryExclude
Mini Soldering Iron Operating Part1
Solder iron tip type-BC21
DC5525 power adaptor (Europe Standard) 1
Earth clamps1
ECCNNot Available
HSCODE8515110000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
2
Is this the TS-100?
on Nov 18,2017
Reply upvote ()
Hi there~ This one is TS-Y02-246.Regards
on Nov 27,2017 09:57 AM
Reply upvote ()
Reply
    View History
    SKU 110990481
    $74.90
    OUT OF STOCK
    $74.90/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
