Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Close-Range Depth Sensing - An operating range of 4-100 cm+ and a recommended range of 7-50 cm, built for near-field robot vision.
  • Stereo Vision - Two stereo cameras output depth data together with color images, with an 18 mm baseline and spatial precision of 1% or better (1280 x 800 at 50 cm, 90% x 90% ROI).
  • High-Speed Imaging - Depth up to 1280 x 800 at 30 fps (848 x 480 at 60 fps) and global-shutter color up to 1280 x 800 at 60 fps, with a depth field of view of H 88 degrees x V 65 degrees.
  • Compact and Payload-Friendly Design - A 42 x 42 x 23 mm housing weighing 68 g, small and light enough for space-constrained and payload-sensitive installations.
  • Synchronization and Triggering - Supports multi-camera synchronization plus software and hardware triggers.
  • Single-Cable USB Type-C Connection - One USB Type-C cable supplies both power (5 V DC, 700 mA or more) and data; USB 3.0 is recommended for full bandwidth. IP54 rated when a protected USB cable is connected and secured.
ParameterSpecification
Operating environmentIndoor and outdoor
Operating range4-100 cm+
Recommended range7-50 cm
Depth technology / baselineStereo vision / 18 mm
Spatial precision1% or better (1280 x 800 at 50 cm, 90% x 90% ROI)
Depth field of viewH 88 degrees x V 65 degrees (plus or minus 3 degrees), 1280 x 800 at 20 cm
Resolution and frame rateUp to 1280 x 800 at 30 fps; 848 x 480 at 60 fps
Color field of viewH 94 degrees x V 68 degrees (plus or minus 3 degrees)
Resolution and frame rateUp to 1280 x 800 at 60 fps
SensorsStereo color, global shutter
Power supply5 V DC, 700 mA or more
Average power consumptionLess than 2 W
Dimensions / weight42 x 42 x 23 mm / 68 g (plus or minus 10 g)
InterfaceUSB Type-C, USB 3.0 and USB 2.0
Ingress protectionIP54 with a suitably protected USB cable connected and secured
MountingBottom: one 1/4-20 UNC and two M3 threaded holes; rear: two M3 threaded holes
Application
Robot Wrist Mounting and Eye-in-Hand Vision
The compact, lightweight Orbbec Gemini 305 can be mounted directly on a robotic arm or wrist for close-range 3D perception. As the camera moves with the arm, it can observe the gripper workspace and occluded areas that fixed or head-mounted cameras may not see, reducing visual blind spots. By capturing the distance, position, and orientation of nearby objects and continuously updating depth information during approach, it helps the robot refine its trajectory and grasping angle for more accurate and reliable manipulation.
Object Recognition and Robotic Grasping
With stereo depth and global-shutter color imaging, the Gemini 305 supports 3D object recognition, pose estimation, point-cloud capture, and depth-guided grasping. Its recommended 7–50 cm working range makes it well suited to manipulation tasks close to the gripper.
3D Perception with Orbbec SDK v2 and ROS 2
Depth and color streams enable 3D perception, point-cloud generation, and depth-to-color alignment in Orbbec SDK v2 and ROS 2 workflows. Windows and Linux platforms, including Jetson and ARM64 systems, are supported.
Viewer example: point cloud and depth-to-color alignment
The Gemini 305 requires Orbbec SDK v2; SDK v1 does not support this model. Reference documents:
Choose the Right Orbbec Gemini Camera
Compare the key specifications and choose the depth camera that best fits your working range, environment, connectivity, and robotic application.
ParameterGemini 2Gemini 335LgGemini 336Gemini 305
Best ForGeneral-purpose robotic vision and SLAMIndustrial robots, AMRs, and long-cable deploymentsOutdoor robots and challenging lightingRobot wrist mounting and close-range grasping
Depth TechnologyActive Stereo IRActive and Passive Stereo VisionActive and Passive Stereo VisionPassive Stereo Vision
Recommended / Ideal Range0.15m - 10m0.25–6 m0.26–3 m7–50 cm
Operating Range0.15–10 m0.17–20 m+0.10–20 m+4–100 cm+
Depth ResolutionUp to 1280 × 800 at 30 fpsUp to 1280 × 800 at 30 fps; 848 × 480 at 60 fpsUp to 1280 × 800 at 30 fpsUp to 1280 × 800 at 30 fps; 848 × 480 at 60 fps
Color ResolutionUp to 1920 × 1080 at 30 fpsUp to 1280 × 800 at 60 fpsUp to 1920 × 1080 at 30 fpsUp to 1280 × 800 at 60 fps
Color ShutterRolling shutterGlobal shutterRolling shutterGlobal shutter
IMUSupportedSupportedSupported—
ConnectionUSB 3.0 Type-CGMSL2/FAKRA-Z and USB modeUSB 3.0 Type-CUSB 3.0/2.0 Type-C
Ingress ProtectionNot specifiedIP65IP5X*IP54*
Dimensions90 × 25 × 30 mm124 × 29 × 36 mm90 × 25 × 30.7 mm42 × 42 × 23 mm
Weight98 g164 g99 g68 g
Key AdvantageWide-range, general-purpose 3D perceptionSecure GMSL2 connection, up to 15 m transmission, and industrial protectionIR-pass filter for more stable depth in glare, shadows, and strong outdoor lightUltra-compact design with optimized near-field depth sensing
Certification
HSCODE8525891900
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
Orbbec Gemini 305 Camerax1
Orbbec Gemini 305 3D Camera
SKU 100021460
The Orbbec Gemini 305 is a compact stereo depth camera designed for close-range robotic vision. Its lightweight 68 g, 42 × 42 × 23 mm body provides a 4–100 cm+ operating range, depth output up to 1280 × 800 at 30 fps, global-shutter color imaging, IP54 protection, and power and data through a single USB Type-C connection. It is ideal for robot wrist mounting, object recognition, grasping, and other space-constrained vision applications.
USD$249.00
You may also add
