Product Details
Wiki & Learn
Reviews
Download PDF
Note: Particle’s MVNO will provide support for LTE M1 connectivity in the US upon initial release. Not in the region? Check out the Boron 2G/3G Kit. See the cellular FAQ for details.
The Boron LTE is a powerful LTE CAT-M1/NB1 enabled development board that can act as either a standalone cellular endpoint or LTE enabled gateway for Particle Mesh networks. It is based on the Nordic nRF52840 and has built-in battery charging circuitry so it’s easy to connect a Li-Po and deploy your local network in minutes.
The Boron is great for connecting existing projects to the Particle Device Cloud or as a gateway to connect an entire group of local endpoints where Wi-Fi is missing or unreliable.
All Particle hardware is designed from the ground up to work with the Device Cloud; a powerful set of tools and infrastructure to build, connect, and manage your IoT fleet. The Device Cloud for Particle Mesh is priced by network. All Particle customers get 3 free months of Device Cloud access for micro networks using a cellular gateway. A micro network is defined as a network with 10 total devices and a single gateway. Please refer to our pricing documentation for more information.
Features:
  • u-blox SARA R410 LTE modem
    - LTE CAT M1/ NB1 module with global hardware support (MVNO support for US only)
    - 3GPP Release 13 LTE Cat M1
  • Nordic Semiconductor nRF52840 SoC
    - ARM Cortex-M4F 32-bit processor @ 64MHz
    - 1MB flash, 256KB RAM
    - IEEE 802.15.4-2006: 250 Kbps
    - Bluetooth 5: 2 Mbps, 1 Mbps, 500 Kbps, 125 Kbps
    - Supports DSP instructions, HW accelerated Floating Point Unit (FPU) calculations
    - ARM TrustZone CryptoCell-310 Cryptographic and security module
    - Up to +8 dBm TX power (down to -20 dBm in 4 dB steps)
    - NFC-A tag
  • On-board additional 2MB SPI flash
  • 20 mixed signal GPIO (6 x Analog, 8 x PWM), UART, I2C, SPI
  • Micro USB 2.0 full speed (12 Mbps)
  • Integrated Li-Po charging and battery connector
  • JTAG (SWD) Connector
  • RGB status LED
  • Reset and Mode buttons
  • Dual SIM support: Nano 4FF (unpopulated) and MFF2
  • U.FL connector for external antenna
  • Meets the Feather specification in dimensions and pinout
  • FCC and PTCRB certified
  • RoHS compliant (lead-free)
Certification
HSCODE8517709000
USHSCODE8517790000
UPC841454121749
EUHSCODE8517180000
COOUnited States
Technical Details
Dimensions51mm x23mm x11mm
WeightG.W 18g
BatteryExclude
Boron LTE dev board1
Cellular flex antenna1
Particle Boron IoT Development Board (Cellular+Mesh+Bluetooth)
SKU 113990598
Particle Boron IoT Development Board (Cellular+Mesh+Bluetooth),mesh networking,end to end,a standalone cellular endpoint or LTE enabled gateway,u-blox SARA R410 LTE modem,LTE CAT M1/ NB1 module,Particle Device Cloud,Thread,Bluetooth 5,BLE
USD$49.00
Discontinued
