seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      PiShow 2.8 Inch Resistive Touch Display
      SKU 104990172
      $16.98$33.95
      14 Available
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      PiShow 2.8"Resistive Touch Display can bring more pleasure to your Raspberry Pi project with no difficulty. The display is specially designed for Model B+ and Raspberry Pi 2 Model B and its diagonal is small enough -2.8"to allow a handily carry but at the same time ensure not too tiny to taxes user’s eyes.
      65K colors and 320x240 pixel resolution provides you a higher resolution compare to the black and white 128x64.. This display integrate touch driver xx2046, communicating with Raspberry Pi through High Speed 48MHz SPI connection. With the touch panel, you could play the Raspberry Pi without the need for a mouse.
      It’s very easy to setup, without the need for a cable or extra power supply, it can be directly attached onto the Raspberry Pi. We have packaged a system kernel with the LCD driver for you, you can upload to many OS for Raspberry pi such as Raspbian Debian fedora.ubunbu
      FEATURES
      • • Up 30 Frames per second,a better viewing experience with no doubts! Watch your movie on Raspberry Pi.
      • • Compatible with Raspberry Pi B+,A+ and Pi 2 Model B
      • • Supports all Operating system on Raspberry Pi
      • • 65K colors and 320x240 Pixel Resolution
      • • Powered directly off Raspberry Pi
      • • Display full GUI output / primary output
      • • High Speed 48MHz SPI connection
      • • Integrated 4-wire Resistive Touch Panel and XPT2046 Driver
      • • UART debug pin out for USB to TTL debug
      COMPATIBLE PRODUCTS
      CompanySizeResolutionRefresh rateSystem InstallationDrive ModeBacklightGamma valueIDROMScreen RotationSpeeed of Bus
      PiShow2.8320*240>=30fpsSupporting various of OS, system kernel has been packed with the LCD driverSPIHigh lightAdjustableYN36MHz
      Normal3.2320*2403-5fpsOutdated documents, highly impossible to upgrade.DBNormalN.ANN16MHz
      Another2.8320*240N/aPackaging system with only Deb installation documentsDC+SPICould controlAdjustableYY32MHz
      4D system2.8320*240HighOriginal sourceSPI-FPGAHigh LightN.ANN.A125MHz
      * PiShow 2.8"Resistive Touch Display is both CE and FCC certified.
      PART LIST
      • • 1 x Raspberry Pi 2.8’’ Touchscreen Display
      DOCUMENTS
      RELATED PRODUCTS
      PiShow 2.4 Inch Resistive Touch Display5 Inch HDMI Display with USB TouchScreen7 Inch HDMI 1280x800 IPS Display
      Technical Details
      Dimensions130mm x 65mm x 35mm
      WeightG.W 67g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
      1
      This LCD uses the fbtft_device driver. Use the following command on raspberry pi 3 ( And probabbly others! ) and it will work with the stock rasbian:modprobe fbtft_device custom rotate=270 verbose=3 name=adafruit28 speed=48000000 gpios=led:18,dc:24,reset:23
      on Jul 02,2017
      Replyupvote ()
      For the curious, I found the pinout by reading the fbt_device.ko file in the wheezy distrbution provided by seeed. Here are the 4 types supported by this driver:pi-tft22areset: 23 dc : 24 led : 18 pi-tft24areset: 04 dc : 18 wr : 17 cs : 27 db00 : 06 db01 : 12 db02 : 13 db03 : 19 db04 : 16 db05 : 26 db06 : 20 db07 : 21 seeed-tft28areset: 23 dc : 24 seeed-tft28breset: 23 dc : 24 led : 18
      on Jul 02,2017 23:11 PM
      Replyupvote ()
      To get the touch screen to work add the following line to /boot/config.txt ------dtoverlay=ads7846,cs=1,speed=2000000,penirq=22,penirq_pull=2,swapxy=0,xmin=230,ymin=200,xmax=3900,ymax=3900,pmin=0,pmax=255,xohms=80
      on Jul 03,2017 03:02 AM
      Replyupvote ()
      You may need to add dtparam=spi=on
      on Jul 03,2017 03:03 AM
      Replyupvote ()
      Reply
      0
      i need drivers for this tft i dont make run
      on Nov 10,2016
      Replyupvote ()
      dont have drivers in dropbox
      on Nov 10,2016 18:30 PM
      Replyupvote ()
      Unfortunatelly, I did not found the driver files there either.I am very dissapointed. Are they in the image files?
      on Mar 27,2017 12:08 PM
      Replyupvote ()
      Reply
      0
      Will this work with the PiZero?
      on Mar 14,2018
      Replyupvote ()
      Hi there~ Unfortunately, this one do not support PiZero. Regards
      on Mar 16,2018 11:00 AM
      Replyupvote ()
      Reply
        View History
        SKU 104990172
        $16.98$33.95
        14 Available
        Maximum Qty: 5
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
