The LDT1-028K is a multi-purpose, piezoelectric sensor for detecting physical phenomena such as vibration or impact. The piezo film element is laminate to a sheet of polyester (Mylar), and produces a useable electrical signal output when forces are applied to the sensing area. The dual wire lead attached to the sensor allows a circuit or monitoring device to process the signal.
Applications:
Sensing direct contact force, Recording time of an event, Counting number of impact events, Measuring impact-related events, Sensing vibration using cantilevered beam, Wakeup switch, Motion detection
Features:
Piezoelectric polymer
Multi-purpose
Vibration sensing
Impact sensing
Laminated
Dual wire lead attached
Minimum impedance: 1 MΩ
Preferred impedance: 10 MΩ and higher
Output voltage: 10mV-100V depending on force and circuit impedance
Storage temperature: -40°C to +70°C [-40°F to 160°F]
Operating temperature: 0°C to +70°C [32°F to 160°F]
