Product Details
Wiki & Learn
Reviews
Download PDF
This prototyping system for the micro:bit is a great way to start making circuits and making experiments. This gives access to the pins on the bottom of the micro:bit.
Please note: micro:bit is NOT included.
This prototyping system uses the specially designed edge connector breakout board for micro:bit. The micro:bit pins are broken out to a row of solderable pads. The SCL and SDA pins are separated at the edge of the board providing easy identification. The PCB includes a prototyping area with 3V, 0V and unconnected rows that can be soldered to. This allows easy connection of switches, sensors and any pull-up or pull-down resistors etc. as required.
This prototyping system is used in conjunction with a small prototype breadboard. This makes it easy to connect additional components using the included jumper wires. No soldering required.
Note: This kit requires assembly.
Features:
  • No soldering is required
  • Breaks out 21 pins from the micro:bit using the pre-built edge connector breakout board for micro:bit
  • Small prototype breadboard included so you can use additional components
  • Run your own custom code from your micro:bit to interact with external components
Certification
ECCNERA99
HSCODE9023009000
Technical Details
Dimensions160mm x95mm x35mm
WeightG.W 140g
BatteryExclude
small prototype breadboard1
jumper wires male to male10
jumper wires male to female10
Perspex mounting plate1
edge connector breakout board for micro:bit - pre-built1
Prototyping system for the micro:bit
SKU 114991413
bbc, micro:bit, education, microbit,
USD$22.95
