seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Raspberry Pi B+&2 Enclosure - White
      SKU 114990124
      $4.46$4.95
      5 Available
      ADD TO CART
      It is a good plastic box for Raspberry Pi, which can protect it with one of these snazzy plastic enclosures?. These cases protect the Raspberry Pi from things like rogue wires that might short it out while still allowing full access to the board! Simply snap the RPi into the bottom half of the enclosure, then snap the two sides together.
      The enclosure provides slots to access the peripheral header, USB ports, Ethernet, SD card, HMDI, composite video, audio, CSI and JTAG connectors as well as feet and vents to ensure the board gets proper cooling and plus-shaped wall mounting slots. All of the status LEDs on the Pi are visible through the case thanks to light pipes embedded in the design. This is a really slick case and once you've gotten your hands on a Raspberry Pi, you'll want to snag one of these to put it in!
      • made with ABS plastic
      • Compatible with Raspberry PiB+/2.
      • equipped with the breather hole
      • smooth surface
      • Easy to fixed
      • Unibody, esy to install
      • Colors: White
      • Case size: 90x60x25mm
      • rubber plastic non-slip mats x 4
      • set screws x 4
      Technical Details
      Dimensions90mm x 60mm x 25mm
      WeightG.W 32g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 114990124
        $4.46$4.95
        5 Available
        ADD TO CART
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
