Product Details
Wiki & Learn
Reviews
Download PDF
Tip
This product is fully compatible with Raspberry Pi 4 (1GB, 2GB,4GB) and hopes you enjoy hacking with Pi 4 and all of other Pi 4 accessories.
Raspberry Pi Motor Driver Board v1.0 is based on the Freescale MC33932 dual H-Bridge Power IC, which can control inductive loads with currents up to 5.0A peak per single bridge. It lets you drive two DC motors with your Raspberry Pi B/B+/A+ and Pi 2 Model B, controlling the speed and direction of each one independently.
Raspberry Pi Motor Driver Board v1.0 support a very wide range of input voltage from 6V~28V. otherwise ,the on board DC/DC converter support a very wide range of input voltage, and can provide a 5V power supply for the Raspberry Pi with 1000mA maximum current. So, you just need one power supply to drive the motors and power up the Raspberry Pi.
Features:
  • Operating Voltage: 6V ~ 28V
  • DC/DC output: 5V 1000mA @ "5V" pin
  • Output Current(For Each Channel ): 2A (continuous operation) / 5A(peak)
  • Output Duty Range: 0%~100%
  • Output short-circuit protection (short to VPWR or GND)
  • Over-current limiting (regulation) via internal constant-off-time PWM
  • Temperature dependant current limit threshold reduction
  • Raspberry Pi compatible
Specification:
  • Compatible: Raspberry Pi ; Other main board via jumpers;
  • Power interface: DC Jack;
  • Dimensions: 91.20 * 56.15mm;
Certification
HSCODE8517709000
USHSCODE8517790000
UPC841454100096
EUHSCODE8517180000
COOCHINA
Technical Details
Dimensions0mm x0mm x0mm
WeightG.W 53g
BatteryExclude
Raspberry Pi Motor Board v1.01
SKU 103030031
USD$48.50
Discontinued
