Raspberry Pi Motor Board v1.0
SKU 103030031
48.50
11 Available
$48.50/ 1pcs+
$43.65/ 10pcs+
Raspberry Pi Motor Driver Board v1.0 is based on the Freescale MC33932 dual H-Bridge Power IC, which can control inductive loads with currents up to 5.0A peak per single bridge. It lets you drive two DC motors with your Raspberry Pi B/B+/A+ and Pi 2 Model B, controlling the speed and direction of each one independently.
Raspberry Pi Motor Driver Board v1.0 support a very wide range of input voltage from 6V~28V. otherwise ,the on board DC/DC converter support a very wide range of input voltage, and can provide a 5V power supply for the Raspberry Pi with 1000mA maximum current. So, you just need one power supply to drive the motors and power up the Raspberry Pi.
Features:
  • Operating Voltage: 6V ~ 28V
  • DC/DC output: 5V 1000mA @ "5V" pin
  • Output Current(For Each Channel ): 2A (continuous operation) / 5A(peak)
  • Output Duty Range: 0%~100%
  • Output short-circuit protection (short to VPWR or GND)
  • Over-current limiting (regulation) via internal constant-off-time PWM
  • Temperature dependant current limit threshold reduction
  • Raspberry Pi compatible
Specification:
  • Compatible: Raspberry Pi ; Other main board via jumpers;
  • Power interface: DC Jack;
  • Dimensions: 91.20 * 56.15mm;
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 53g
BatteryExclude
Raspberry Pi Motor Board v1.01
ECCNEAR99
HSCODE8503001000
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 103030031
    $48.50
    11 Available
    $48.50/ 1pcs+
    $43.65/ 10pcs+
    • Description
    • Technical Details
    • Learn
    • Reviews
    • Questions and Answers
    SUBMIT
