Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Equipped with an emergency stop switch.
Electrical Interface Definition
Pin
Terminal Mark
Terminal Function
Terminal Specification
1
GND
CAN interface ground
Frame-type crimp terminal,
wire hole diameter Φ1.9mm
2
L
CANL
3
H
CANH
4
R-
Connect to braking resistor
5
R+
6
48V power interface
XT30
7
Robot arm wiring terminal
XT30(2+2)
Certification
HSCODE8537109090
USHSCODE8517620090
UPC
EUHSCODE8471707000
COOCHINA
Circuit Protection and Emergency Stop Switch Module for reBot Arm B601-RS
SKU 100091373
This product is specifically designed to handle the regenerative braking kinetic energy of the reBot Arm B601-RS joint module when operating under high rotational speed and heavy load conditions. This ensures that the power supply voltage does not rise excessively due to the regenerative energy feedback, thus preventing the occurrence of an error message indicating excessive bus voltage and resulting in machine shutdown.
USD$59.90
You may also add
