Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
The RF Explorer SMA Push-ON Male/Female adapter is great for repetitive connections to the SMA port. Normal threaded SMA ports are useful for permanent connection but this Push-ON adapter makes it very easy to plug-unplug a cable or device with just a slide gesture, no need to screw or thread the SMA connector.
Typically used for testing or momentary antenna measurements, these Push-ON adaptors are hard to find at this quality and price in low quantities.
The Push-ON adaptor is the same quality part included in the RF Explorer Near Field Antenna Kit. We benefit from our volume orders and therefore can pass this save cost to you.
  • Quality golden Push-ON connector on the Male side, normal threaded Female side.
  • Convenient for quick connections with a gesture
  • Easy to use for repetitive measurement
Certification
HSCODE9030900090
USHSCODE9030904600
EUHSCODE9030900000
COOTAIWAN,CHINA
Technical Details
Dimensions170mm x90mm x90mm
WeightG.W 4.5g
BatteryExclude
Impedance50ohm
ConnectorPush-ON SMA Male, standard Female
Insulating MaterialTeflon
Contact materialGold (>3 micro inches)
Body materialBrass/Beryllium Copper/Nickel
Bandwidth6Ghz
VSWR<1.5
SMA Push-ON Male/Female adapter1
SKU 320160105
USD$9.78
Discontinued
You may also add
