Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
This product is the Seeed Studio XIAO RP2040 Plus, the upgraded variant of XIAO RP2040 with 15 additional SMD GPIOs and integrated Li-ion battery management. The board and two 7-pin headers are included. No battery, USB cable, or other accessories are included.
Overview
Inspired by the XIAO Plus design language established by XIAO nRF52840 Plus, XIAO nRF52840 Sense Plus, and XIAO ESP32-S3 Plus, the new Seeed Studio XIAO RP2040 Plus expands the Raspberry Pi RP2040 family with additional GPIO resources, integrated Li-ion battery management, and a standardized backside layout for seamless hardware integration.
Powered by Raspberry Pi's RP2040 dual-core ARM Cortex-M0+ processor, XIAO RP2040 Plus brings enhanced expandability to the tiny and versatile XIAO RP2040. While maintaining all the powerful features including Arduino, MicroPython, CircuitPython, and PIO state machines, the Plus variant features redesigned castellations and backside pad layout, providing 15 additional GPIOs and integrated Li-ion battery management. It is ideal for advanced IoT projects, battery-powered wearables, custom PCBA designs, and production-ready SoM applications.
Production-Ready Design with FREE PCBA Support
As an addition to the Seeed Studio XIAO family, the XIAO RP2040 Plus remains the classic XIAO design (thumb-size, SMD, stamp holes). All these features make it a perfect fit for either space-limited applications, or a production-ready System on Module (SoM) for your PCBA designs. Through our Fusion PCBA Sponsorship program, you can not only enjoy the lowest unit prices for all XIAO modules from our Fusion Open Parts Library, but also fabricate and scale your XIAO-based PCBA designs at low cost (30% off) with FREE Design for Manufacturing consulting services, streamlining your journey from prototype to production.
Note:
XIAO SoM User Manual open-sources all hardware and software materials of XIAO, providing professional product design guidelines to help you accelerate ideas off the ground, streamline product design, providing a seamless experience from module selection to mass production. You can check here to see more info.
  • High-Performance MCU
Dual-core ARM Cortex-M0+ processor running at up to 133 MHz, equipped with Raspberry Pi's unique PIO (Programmable I/O) state machines. Fully compatible with Arduino, MicroPython, CircuitPython, C/C++ SDK, Rust, Go, and Zephyr for any project from learning to production.
  • Multi-Language SDK Support
Code with Arduino IDE for rapid prototyping, leverage C/C++ SDK for optimal performance, script in MicroPython/CircuitPython for quick iteration, or develop with Rust, Go, and Zephyr for modern applications. Backed by comprehensive documentation and an active Raspberry Pi community, you'll find abundant examples and resources to kickstart your projects.
  • Efficient Power Management
The onboard PMIC enables direct Li-ion battery connection and provides 3V3/BAT backflow protection for convenient battery-powered applications.
XIAO RP2040 Plus also integrates a software-controlled battery voltage monitoring circuit. GPIO24 (BAT_EN) is used to enable the battery sensing circuit, while GPIO29 (A3) reads the battery voltage through the ADC, allowing the battery status to be monitored directly in software.
  • Expanded I/O
15 additional GPIOs through redesigned 1.27mm-pitch SMD castellations, expanding the total available GPIO count for advanced applications. These extra I/Os enable direct connection of more sensors, displays, actuators, and peripherals without requiring external I/O expanders, making XIAO RP2040 Plus more flexible for complex embedded projects and production-ready SoM designs.
  • Universal Compatibility — Standardized Backside Layout
Standard backside layout with aligned battery pads and debugger pads, ensuring compatibility with all current and upcoming XIAO expansion boards. One XIAO Plus footprint, infinite project possibilities.
  • Classic XIAO Form Factor
21 x 17.8mm thumb-sized design with 2.54mm pin headers, single-sided mounting for wearables and space-constrained projects.
  • XIAO Accessory Add-ons Compatibility
Natively compatible with the full XIAO Add-on ecosystem — from expansion boards, sensors and displays to connectivity modules and actuators (Grove Expansion, CAN-Bus, LoRa module, LED Matrix, Vision AI Sensor, Round Display, L76K GPS module, 2-Mic Array, ePaper Displays, mmWave sensor, AC relay, Bus Servo Driver and many more).
  • Software-Controlled Battery Monitoring
Monitor battery status directly in software with the onboard battery sensing circuit. GPIO24 (BAT_EN) controls the sensing circuit, while GPIO29 (A3) is used to measure the battery voltage through the ADC. The sensing circuit can be enabled only when needed, providing flexible battery monitoring for portable and battery-powered applications.
Product NameSeeed Studio XIAO RP2040Seeed Studio XIAO RP2040 Plus
ChipsetRaspberry Pi RP2040
ProcessorDual Cortex M0+ up to 133 MHz
RAM264 KB SRAM
Flash2 MB Onboard Flash
InterfaceGPIO Pin x14
Digital Pin x11
Analog Pin x4
I2C x1
UART x1
SPI x1
PWM x11
GPIO Pin x29
Digital Pin x26
Analog Pin x4
I2C x2
UART x1
SPI x1
PWM x26
OnboardUser LED (3 Colors) x1
Power LED x1
RGB LED x1
Reset Button x1
Boot Button x1
User LED x1
Charge LED x1
RGB LED x1
Reset Button x1
Boot Button x1
Battery Management (PMIC)NoneOnboard PMIC
PowerInput Voltage (Type-C): 5V
Input Voltage (BAT): 5V
Working Temperature-20 to 70°C
Dimensions21 x 17.8mm
Software CompatibilityArduino, PlatformIO, MicroPython, CircuitPython, TinyGo, Rust, Zephyr,and more to come
Varients
Hardware Overview
  • PinOut
Application
  • Learning & Education – Arduino, MicroPython, CircuitPython, TinyGo, Rust, embedded systems basics
  • USB HID Devices – Custom keyboards, stream decks, arcade controllers, MIDI interfaces
  • Wearable Projects – Smart accessories, LED clothing, wrist devices, sensor wearables
  • IoT & Sensors – Environmental monitoring, smart home panels, weather stations, MQTT
  • Display Projects – LED matrices, POV displays, rotating LED spheres
  • Development – Rapid prototyping, hardware testing, PCB validation
  • Robotics – Basic motor control, sensor integration, automation
  • Audio/Video – Sound processing, media controls, visualizations
  • Battery-Powered Devices – Portable data loggers, wireless sensor nodes, remote monitoring, wearables with on-board Li-ion battery, asset trackers
  • Mass-Production SoM Designs – Mid-to-high volume products needing extra I/Os and integrated battery management
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
Seeed Studio XIAO RP2040 Plus×1
7-Pin Header× 2
SKU 100059977
XIAO RP2040 Plus, powered by Raspberry Pi's RP2040 dual-core ARM Cortex-M0+ processor, brings enhanced expandability to the tiny and versatile XIAO RP2040. While retaining support for Arduino, MicroPython, CircuitPython, and PIO state machines, the Plus variant adds 15 GPIOs through redesigned SMD castellations, integrated Li-ion battery management, and software-controlled battery voltage monitoring via GPIO24 and GPIO29. It is ideal for advanced embedded projects, battery-powered devices, and production-ready SoM designs.
XIAO Dev Board
Pin Header
Package
USD$4.90
