Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
The SenseCAP M2 Multi-Platform LoRaWAN® Gateway is a fully customizable and open-sourced LoRaWAN® gateway that supports connection to various network servers. It supports global LoRaWAN® frequency plans from 865 MHz to 923 MHz and can be used in multiple LoRaWAN® applications like smart building, environmental monitoring systems, precision farming, etc. It has wide-range coverage and strong signal output capability and other features, making it the perfect gateway for building a LoRaWAN® network.
Note: The SenseCAP M2 Multi-Platform LoRaWAN® Gateway doesn't support the Helium network. It can not be connected with SenseCAP Hotspot APP and SenseCAP Dashboard.
SenseCAP M2 Multi-Platform LoRaWAN® Gateway supports multiple applications like smart agriculture, smart city, or any smart project that requires network densification, providing both unique superior coverage and operational excellence.
The Gateway can be set up easily out of the box. Users can bind and manage the device through SenseCAP Mate APP and SenseCAP Portal in 4 steps. After that, users can start configuring the sensors in the same way to create the LoRaWAN® network solutions.
  1. Scan the QR code for device binding
  2. Connect gateway to internet and power on
  3. Check gateway status on the SenseCAP platform
  4. Connect sensors to the network and upload data to the cloud
SenseCAP M2 Multi-Platform LoRaWAN® Gateway can be configured in 2 ways:
  1. Wi-Fi/ Ethernet access to the SenseCAP Local Console
  2. Access the SenseCAP Local Console via SenseCAP Portal remotely
Additionally, If you want to deploy the SenseCAP M2 Multi-Platform LoRaWAN® Gateway outdoors, you might need to apply shell accessories to meet the requirements for outdoor deployments. Check the SenseCAP Ourdoor Enclosure with high robustness for quick deployment.
  • Open-Source Support: Easily customize and develop users own LoRaWAN solutions for seamless integration into their specific use cases. Check out details here.
  • Support Multiple LoRaWAN® Network Servers: Compatible with multiple LNS like AWS, TTN, ChirpStack, etc. via using the Packet Forwarder / Basics™ Station mode.
  • Built-in LoRaWAN Network Server: Based on Chirpstack, provides a fast and reliable solution for launching a LoRaWAN network.
  • Built-in SenseCAP Local Console for Configuration: Provides a simple setup experience to configure the device on Web UI through Wi-Fi AP and Ethernet.
  • Support Power-over-Ethernet (PoE): For users who need to power the gateway on Ethernet instead of an extra power supply cable, the PoE feature is also added to this device, making your deployment more reliable and faster.
  • Wide-range Coverage and Strong Signal: Provides up to 10km of LoRaWAN® coverage and strong signal, allowing users to send data with extremely long ranges at low data rates.
  • Excellent and Stable Performance: The gateway is powered by the mature hardware solution MT7628 and Semtech SX1302 baseband Long Range chip. It supports Cellular(optional)、Wi-Fi and Ethernet internet connection.
  • Professional Management Tools and Cloud Services: Users could easily set up the gateway in a few simple steps via Web Interface. SenseCAP Portal and SenseCAP Local Console are also developed for users to monitor and manage the gateway efficiently and easily.
ProcessorMT7628(MIPS24KEc@580MHz)
RAMDDR2 128MB
Flash32MB
Long Range Gateway ChipSX1302
Channel8
LoRaWAN® ProtocolV1.0.3 Class A/Class B/Class C
Frequency PlanIN865/EU868/RU864/US915/AU915/KR920/AS923
Note: The listed frequency plans refer to the bands supported by the built-in LoRa chip(SX1302), not all bands available on a single gateway. Please refer to the LoRaWAN® Frequency below for model selection.
Long Range Sensitivity-125dBm @125KHz/SF7
-139dBm @125KHz/SF12
Long Range TX PowerUp to 26 dBm
AntennaLong Range: 3dBi External Antenna with Base
Wi-Fi: Internal Antenna
4G Antenna:
Main Antenna: 3dBi @ PCB Antenna
DIV Antenna:4dBi @FPC Antenna
Antenna Impedance50 Ohm
Wi-FiSupport 2.4 GHz 802.11 b/g/n
Ethernet1xRJ45 (10M / 100 M), PoE PD support
4G BandLTE-FDD: B1/B2/B3/B4/B5/B7/B8/B28
WCDMA: B1/B2/B4/B5/B8
4G FeaturesSupport non-CA Cat 4 FDD
LTE-FDD: Max 150Mbps (DL), Max 50Mbps (UL)
UMTS FeaturesSupport 3GPP R8 DC-HSDPA, HSPA+, HSDPA, HSUPA and WCDMA
DC-HSDPA: Max 42Mbps (DL) HSUPA: Max 5.76Mbps (UL)
WCDMA: Max 384Kbps (DL), Max 384Kbps (UL)g
Input VoltageDC 12V - 2A
PoE (IEEE 802.3 af), 40V-57V DC
InterfacesEthernet RJ45 * 1
RP-SMA Female Antenna Connector * 1
Micro SD Card Slot (Future use) * 1
USB Type-C (Console) * 1
Management SoftwareWeb
Dimension143.6x135x34mm (connector not included)
150.6x135x34mm (connector included)
Package: 340*230*65mm
Operating Temperature-20°C to 55°C
Relative Humidity0% - 85% (non-condensing)
LoRaWAN® Frequency
Frequency Band
Switchable Frequency Band
EU868
IN865/RU864
US915
AS923
Hardware Overview
Application
  • Smart Agriculture
  • Smart Building
  • Environmental Monitoring
  • Other Wireless Sensing Applications
Certification
HSCODE8517629990
USHSCODE8517620090
UPC
EUHSCODE
COOCHINA
SenseCAP M2 Multi-Platform LoRaWAN® Gateway1
Adapter1
3dBi LongRange Antenna1
The gateway is a standard LoRaWAN® gateway designed for indoor scenarios. In addition, if you want to maximize the capability of the gateway in the outdoor environment, please consider applying an outdoor enclosure.
The SenseCAP Mate can be used to bind the gateway and manage the device. It is a powerful tool for the usage of SenseCAP M2 Multi-Platform LoRaWAN® Gateway. You can download the APP here: 1. iOS; 2. Google Play; 3. App Center
SenseCAP M2 Multi-Platform LoRaWAN Indoor Gateway(SX1302-4G) - AU915
SKU 100087424
Usage
Network Connection
Region
USD$159.00
You may also add
